Node-RED version: v0.18.7
Node.js version: v8.11.2
node-red-node-pi-sense-hat@0.0.15
I spent a lot of time trying to get the flip to work. The help says:
Flip the screen
Format: F
axis must be either H or V to flip on the horizontal or vertical axis respectively.
So I tried F<V> and it didn't work. I tried F<v>, f<v>, f<V> - I tried F(V) and F[V]. I even tried digging thru the code but nothing worked till I finally tried FV.
My suggestion is to change the 'Node Help' for 'Rotate the screen' and 'Flip the screen'
Rotate the screen
Format: R
angle must be 0, 90, 180 or 270.
Flip the screen
Format: F
to
Rotate the screen
Format: R
Example: R270Flip the screen
Format: F
Example: FH
and for 'Set the screen brightness' from:
Format: D
level must be 0 (low) or 1 (high).
to:
Format: D
Example: D1
