I'm setting up a Pi3B+ to use the "official" 7" touch screen and was shocked to find it had node-red installed, would be pleasant if it weren't such an old version!
node-red v1.0.6
nodejs v10.23.1
I assume running the bash install script will set things right, whcih is running as I type this, but this might generate headaches for the fine folks supporting node-red, so I thought a heads-up might be in order.
Its been a while since I setup a Pi, but last time node-red was not part of the default installation which was considered a good thing.
