Hi everyone.
I'm using using Odroid-C4 and node red as a monitor for my GPS.
I used by docker compose to install node-red
I don't know why node red is exited with code 0
Any hints?
Logs
root@odroid:/var/lib/docker# docker-compose up
Creating network "docker_node-red-net" with the default driver
Creating docker_node-red_1 ... done
Attaching to docker_node-red_1
node-red_1 |
node-red_1 | > node-red-docker@2.2.2 start /usr/src/node-red
node-red_1 | > node $NODE_OPTIONS node_modules/node-red/red.js $FLOWS "--userDir" "/data"
node-red_1 |
node-red_1 | 25 Mar 10:22:48 - [info]
node-red_1 |
node-red_1 | Welcome to Node-RED
node-red_1 | ===================
node-red_1 |
node-red_1 | 25 Mar 10:22:48 - [info] Node-RED version: v2.2.2
node-red_1 | 25 Mar 10:22:48 - [info] Node.js version: v14.18.2
node-red_1 | 25 Mar 10:22:48 - [info] Linux 4.9.277-75 arm64 LE
node-red_1 | 25 Mar 10:22:49 - [info] Loading palette nodes
node-red_1 | 25 Mar 10:22:51 - [info] Settings file : /data/settings.js
node-red_1 | 25 Mar 10:22:51 - [info] Context store : 'default' [module=memory]
node-red_1 | 25 Mar 10:22:51 - [info] User directory : /data
node-red_1 | 25 Mar 10:22:51 - [warn] Projects disabled : editorTheme.projects.enabled=false
node-red_1 | 25 Mar 10:22:51 - [info] Flows file : /data/flows.json
node-red_1 |
node-red_1 | ---------------------------------------------------------------------
node-red_1 | Your flow credentials file is encrypted using a system-generated key.
node-red_1 |
node-red_1 | If the system-generated key is lost for any reason, your credentials
node-red_1 | file will not be recoverable, you will have to delete it and re-enter
node-red_1 | your credentials.
node-red_1 |
node-red_1 | You should set your own key using the 'credentialSecret' option in
node-red_1 | your settings file. Node-RED will then re-encrypt your credentials
node-red_1 | file using your chosen key the next time you deploy a change.
node-red_1 |
node-red_1 | 25 Mar 10:22:51 - [info] Server now running at http://127.0.0.1:1880/
node-red_1 | 25 Mar 10:22:51 - [info] Starting flows
node-red_1 |
node-red_1 |
node-red_1 | 25 Mar 10:22:57 - [info]
node-red_1 |
node-red_1 |
node-red_1 | 25 Mar 10:22:57 - [info] Node-RED version: v2.2.2
node-red_1 | 25 Mar 10:22:57 - [info] Node.js version: v14.18.2
node-red_1 | 25 Mar 10:22:57 - [info] Linux 4.9.277-75 arm64 LE
node-red_1 | 25 Mar 10:22:57 - [info] Loading palette nodes
node-red_1 | 25 Mar 10:23:00 - [info] Settings file : /data/settings.js
node-red_1 | 25 Mar 10:23:00 - [info] Context store : 'default' [module=memory]
node-red_1 | 25 Mar 10:23:00 - [info] User directory : /data
node-red_1 | 25 Mar 10:23:00 - [warn] Projects disabled : editorTheme.projects.enabled=false
node-red_1 | 25 Mar 10:23:00 - [info] Flows file : /data/flows.json
node-red_1 |
node-red_1 |
node-red_1 |
node-red_1 |
node-red_1 | 25 Mar 10:23:00 - [info] Server now running at http://127.0.0.1:1880/
node-red_1 | 25 Mar 10:23:00 - [info] Starting flows
docker_node-red_1 exited with code 0
docker-compose
# Node-RED Stack or Compose
# docker stack deploy node-red --compose-file docker-compose-node-red.yml
# docker-compose -f docker-compose-node-red.yml -p myNoderedProject up
version: '3.7'
services:
node-red:
image: nodered/node-red:latest
restart: always
user: "1000"
environment:
- TZ=Asia/Seoul
ports:
- "1880:1880"
- "20001:20001"
- "20002:20002"
devices:
# - "/dev/serial/by-id/usb-FTDI_USB__-__Serial_Converter_FT2MLPNJ-if00-port0:/dev/serial/by-id/usb-FTDI_USB__-__Serial_Converter_FT2MLPNJ-if00-port0"#
- "/dev/ttyACM0:/dev/ttyACM0"
user: root:root
networks:
- node-red-net
volumes:
- ./node-red-data:/data:rw,Z
# - ./output:/usr/src/node-red/data:rw
# - ./output:/usr/src/node-red/data:rw,Z
# - ./node-red-data:/data:rw
tty: true
stdin_open: true
networks:
node-red-net:
root@odroid:/var/lib/docker# cat /etc/issue
Ubuntu 20.04.3 LTS \n \l
