Node red on RPi refuse to connect to MySQL DB running on another RPi on local LAN
I have my Node-RED on a RPi 192.168.1.23 and MySQL on another RPi 192.168.1.24
I used to have Node-RED, MQTT server and MySQL DB server on one RPi , but it struggled so I am splitting it up to two RPi with Node-RED and MQTT running on a RPi 4B 8 GB - Works perfect with more connections now.
My next phase is to connect to a newly created DB on a separate RPi but I just cannot figure out how to change privileges to allow the connection.
My injection appears to be just fine:-
\var temperature = msg.payload.DS18B20.Temperature;
var string1 = "INSERT INTO `TestTemp`(`index`, `create_date`, `main_source`, `source`, `reading`)"; // string1:
var string2 = " VALUES (NULL, current_timestamp(),'1856',"; // string2
var string3 = "'Office',"; // string3
var string4 = temperature; // string4
var string5 = ")"; // string5
msg.topic = string1 + string2 + string3 + string4 + string5; // Concatenate strings
But the connection node fails with this message:
3/27/2023, 5:48:51 PMnode: MySQL on 24
msg : string[22]
"Database not connected"
3/27/2023, 5:48:57 PMnode: MySQL_RPi
msg : error
"Error: connect ECONNREFUSED 192.168.1.24:3306"
The MySQL connection
The PHPmyAdmin where I successfully inserted data using the myPHPAdmin interface
User privileges using commandline
MariaDB [(none)]> SELECT User,Host FROM mysql.user WHERE User='erasmi';
| User | Host |
| erasmi | 6mtchurchill |
| erasmi | localhost |
2 rows in set (0.006 sec)
MariaDB [(none)]>
User privileges from phpMyAdmin
I need more simplistic guidence than these detailed websites as it confuses me just more
javascript - Node.js Error: connect ECONNREFUSED - Stack Overflow
https://community.progress.com/s/article/Connection-Error-ECONNREFUSED-Connection-refused-by-the-server
Running the command: sudo service mysql status
 mariadb.service - MariaDB 10.5.15 database server
     Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled)
     Active: active (running) since Fri 2023-03-24 11:17:12 SAST; 3 days ago
       Docs: man:mariadbd(8)
             https://mariadb.com/kb/en/library/systemd/
    Process: 507 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS)
    Process: 524 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
    Process: 535 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= ||   VAR=`cd /usr/bin/..; /usr/bin/galera_recovery`; [ $? -eq 0 ]   && systemctl set-enviro>
    Process: 653 ExecStartPost=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
    Process: 655 ExecStartPost=/etc/mysql/debian-start (code=exited, status=0/SUCCESS)
   Main PID: 609 (mariadbd)
     Status: "Taking your SQL requests now..."
      Tasks: 14 (limit: 1595)
        CPU: 1min 6.376s
     CGroup: /system.slice/mariadb.service
             └─609 /usr/sbin/mariadbd
Mar 24 11:17:12 MySQLPi /etc/mysql/debian-start[661]: There is no need to run mysql_upgrade again for 10.5.15-MariaDB.
Mar 24 11:17:12 MySQLPi /etc/mysql/debian-start[661]: You can use --force if you still want to run mysql_upgrade
Mar 24 11:17:12 MySQLPi /etc/mysql/debian-start[673]: Checking for insecure root accounts.
Mar 24 11:17:12 MySQLPi /etc/mysql/debian-start[679]: Triggering myisam-recover for all MyISAM tables and aria-recover for all Aria tables
Mar 25 12:51:44 MySQLPi mariadbd[609]: 2023-03-25 12:51:44 571 [Warning] Access denied for user 'erasmi'@'localhost' (using password: YES)
Hi @fritserasmus
ECONNREFUSED means the port 3306 is not offering any services on the IP Address of 192.168.1.24
  • MySQL is not configured to listen on 192.168.1.24 (check my.ini)
  • Some OS/Router level firewall setting, that actively rejects the connection.
This is quite different to ACCESS DENIED - this is a network level refusal to gain access to the MySQL instance
Have you made any changes to /etc/mysql/mariadb.conf.d/50-server.cnf to allow connections from other devices?
Is that the my.ini equivalent? - I have only ever used MySQL - but know they are almost the same thing right? :man_shrugging:
EDIT:
Oh hang-on my.ini is windows only :sweat_smile:
I found I had to enter the IP address of the remote RPi that is accessing the dB on the main RPi.
I couldn't get it to recognise the 'host-name'. Hope this helps?
db_access
Thanks for checking,
Yes, I did.
@dynamicdave ,
This is how have the connection configured:
Is this what you meant?
I still get the error:
3/27/2023, 8:59:23 PMnode: MySQL on 24
msg : string[22]
3/27/2023, 8:59:30 PMnode: MySQL_RPi
msg : error
Any further suggestions?
I think you are showing me the settings in the Node-RED mysql node.
I was refering to the User accounts overview inside 'phpmyadmin' you showed near the start of the thread.
I think you need an entry in the User Accounts for 192.168.1.23 in order for it to access 192.168.1.24
Although I use the command line $sudo mysql -u root -p to manage my users/privileges/passwords, I'm sure you can do the same thing using 'phpmyadmin' from a web browser.
For what its worth - I seem to remember I went through a lot of trial-and-error before I got things to work!!
Got that now
| User   | Host         |
| erasmi | 192.168.1.23 |
3 rows in set (0.005 sec)
But still no connection.
3/27/2023, 10:30:57 PMnode: MySQL_RPi
msg : error
3/27/2023, 10:31:03 PMnode: MySQL on 24
msg : string[22]
BTW:
the User name, is the user I use to log onto the DB, is that correct?
Just to make the feedback more complete by adding first few lines of "50-server.cnf
# * Basic Settings
user                    = mysql
pid-file                = /run/mysqld/mysqld.pid
basedir                 = /usr
datadir                 = /var/lib/mysql
tmpdir                  = /tmp
lc-messages-dir         = /usr/share/mysql
lc-messages             = en_US
skip-external-locking
# Broken reverse DNS slows down connections considerably and name resolve is
# safe to skip if there are no "host by domain name" access grants
#skip-name-resolve
# Instead of skip-networking the default is now to listen only on
# localhost which is more compatible and is not less secure.
bind-address            = 192.168.1.23
I changed bind-address to 0.0.0.0 and Node-RED connected successfully.
Problem SOLVED!!
Pleased you got it working.
Cough cough :wink:
glad you got to the bottom of it!
Although, your trying to connect to 192.168.1.24 not 192.168.1.23 - I mean its working so :man_shrugging:
You may need to adjust PMA to connect to the lan address, instead of localhost - I'm not sure.
