Node-RED restart require every time when i install updated version of my Nodes
I'm new in Node-RED' Nodes development, I have created a set of nodes to perform some specific tasks, These Nodes require continuous modifications and updates.
But whenever i install update of my Nodes in Node-RED, Node-RED force me to restart the Node-RED. I can see that the update is not required by other Nodes in Node-RED, That mean i'm doing something wrong.
Can anyone please explain(if possible) how it works.
Thanks in advance.
When developing, it is easiest to work on a local copy of node-red. You can then install your developing nodes using:
cd ~/.node-red
npm install /path/to/your/dev/code/
But you still need to restart node-red to pick up the latest changes to the .js file. You can simplify this by using something like PM2 with its watch feature - simply watch for changes to any key files and force a restart.
Hope this helps.
Thanks @TotallyInformation for your valuable and fast reply, using PM2 will also helps me in creating Nodes better.
But, I think i'm not able to explain my question correctly.
Actually, My Nodes are already published on npm and i'm installing my updated node from Node-RED' pattels manager. When install was complete, Node-RED force me to restart(in my case).
While updating other nodes (like dashboard and other good nodes) restart is not forced, Nodes simply get updated.
Am I missing something or third party nodes require restart. (Sorry for dump question)
What dependencies have you got in the node that does this?
Ah, I see. Odd. I've never worked out what causes that myself. Not had it happen on one of my nodes but I've certainly seen it happen.
My experience. After installing a new node, no restart is needed. But updating any node Node-RED requires a restart. This is also true for dashboard.
