I am using @tq-bit/node-red-contrib-server-sent-events : sse-server (node-red-contrib-server-sent-events (node) - Node-RED). I have setup a small flow , But Im unable to receive the message in the data. Can anyone let me know how I can do this?
A
You know that you need to use the matching client node?
Instructions are in the README and there is also an example flow that is referenced there.
node-red-contrib-server-sent-events (node) - Node-RED (nodered.org)
Hi @TotallyInformation I have implemented the client in a separate HTML program.
I don't think that will work. As a trial, add the client node to see if it works.
