Node-red Sqlite SELECT syntax error
Hi all.
I'm getting an error in a SELECT command from Sqlite DB.
The error msg is : "Error: SQLITE_ERROR: near "Index": syntax error"
The command I output to Sqlite DB:
var newMsg = {
// "topic": "SELECT * FROM MonthKwh ORDER BY Index DESC LIMIT 100"} *)
"topic": "SELECT * FROM MonthKwh ORDER BY Index DESC LIMIT 1"}
//"topic": "SELECT Month FROM MonthKwh"}
return newMsg;
The TABLE MonthKwh structure is:
CREATE TABLE MonthKwh (
Index INTEGER PRIMARY KEY AUTOINCREMENT,
Year INTEGER,
Month INTEGER,
XKwh REAL,
FKwh REAL
What I'm trying to do:
If the last row is in the same actual month, I want to overwrite this last row.
If the actual month is not the same of last row, then I need to INSERT a new row.
Thanks in advance.
Pau Torras
Go take a look at this and then see if you understand your issue.
Thanks @zenofmud,
With the information provided, I see the problem is the name field of the column Index.
ÂżIsn't it?
That's what the error message was telling you. Basically never use reserved words for column names :wink:
