Hi
This is my first time working with Sqlite.
I'm trying to test clauses and the SELECT clause to read just 3 columns give me Sintax error near FROM .
I've attached the flow.
SQLITE test.txt (4.0 KB)
Thank you very much for some help.
We don't need to see the flow, not yet anyway. Add a debug node showing the input to the SQL node, set it to show the complete message. Also add a debug node showing the output of the SQL node. Show us what they show.
For the future it is better to paste flows and data inline here.
I did what you asked me and this is the debug tab when I push a SELECT clause.
I'm not quite sure if this what you need..... then push on inject node with the SELECT for some db columns is showed on sqlite in.
1/5/2020, 12:10:37 PMnode: sqlite IN
SELECT currentdate,currenttime, hp, FROM hvac; : msg.payload : number
2020-01-05T20:10:37.876Z
The output node at sqlite node does not appear on debug tab and the sqlite node debug tab is the following:
1/5/2020, 12:10:37 PMnode: Sqlite
msg : error
"Error: SQLITE_ERROR: near "FROM": syntax error"
i think it may be the comma after hp.
@E1cid
Yes men !!!! it does work.
You made my day !!!
Thank you so much.
not sure how your table is set up, but do you want all rows as you can set a limit.
the comma means it was expecting another column name. Thats why it threw a syntax error. It gave a clue, as it said the FROM threw the error.
