Node red starts but not as a service
I can start node red normally, but while installing it as a service it does not start, providing an error
Starting as a service, it does not work:
pi@raspberrypi:~/shared/mqtt-topic-logger/tlogs/tele/tasmota $ sudo systemctl start node-red
pi@raspberrypi:~/shared/mqtt-topic-logger/tlogs/tele/tasmota $ sudo systemctl status node-red
● node-red.service - Node-RED
   Loaded: loaded (/etc/systemd/system/node-red.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Mon 2020-01-06 15:56:38 GMT; 2min 3s ago
  Process: 2377 ExecStart=/usr/bin/node-red-pi --max-old-space-size=128 -v (code=exited, status=1/FAILURE)
 Main PID: 2377 (code=exited, status=1/FAILURE)
Jan 06 15:56:38 raspberrypi node-red[2377]:     at Object.<anonymous> (/usr/lib/node_modules/node-red/red.js:98:50)
Jan 06 15:56:38 raspberrypi node-red[2377]:     at Module._compile (internal/modules/cjs/loader.js:778:30)
Jan 06 15:56:38 raspberrypi node-red[2377]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
Jan 06 15:56:38 raspberrypi node-red[2377]:     at Module.load (internal/modules/cjs/loader.js:653:32)
Jan 06 15:56:38 raspberrypi node-red[2377]:     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
Jan 06 15:56:38 raspberrypi node-red[2377]:     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
Jan 06 15:56:38 raspberrypi node-red[2377]:     at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
Jan 06 15:56:38 raspberrypi node-red[2377]:     at startup (internal/bootstrap/node.js:283:19)
Jan 06 15:56:38 raspberrypi systemd[1]: node-red.service: Main process exited, code=exited, status=1/FAILURE
Jan 06 15:56:38 raspberrypi systemd[1]: node-red.service: Failed with result 'exit-code'.
Starting normally, it works
pi@raspberrypi:~ $ node-red-pi --max-old-space-size=256
6 Jan 15:38:57 - [info]
Welcome to Node-RED
6 Jan 15:38:57 - [info] Node-RED version: v1.0.3
6 Jan 15:38:57 - [info] Node.js  version: v10.18.0
6 Jan 15:38:57 - [info] Linux 4.19.75+ arm LE
6 Jan 15:39:12 - [info] Loading palette nodes
6 Jan 15:39:51 - [info] Settings file  : /home/pi/.node-red/settings.js
6 Jan 15:39:51 - [info] Context store  : 'default' [module=memory]
6 Jan 15:39:51 - [info] User directory : /home/pi/.node-red
6 Jan 15:39:51 - [warn] Projects disabled : editorTheme.projects.enabled=false
6 Jan 15:39:51 - [info] Flows file     : /home/pi/.node-red/flows_raspberrypi.json
your credentials.
6 Jan 15:39:51 - [info] Starting flows
6 Jan 15:39:55 - [info] Started flows
6 Jan 15:39:55 - [info] Server now running at http://127.0.0.1:1880/
6 Jan 15:39:55 - [info] [mqtt-broker:localhost] Connected to broker: mqtt://localhost:1883
^C6 Jan 15:50:12 - [info] Stopping flows
6 Jan 15:50:13 - [info] [mqtt-broker:localhost] Disconnected from broker: mqtt://localhost:1883
6 Jan 15:50:13 - [info] Stopped flows
Working on a Raspberry Pi Model B Revision 2.0 - 512MB, with Raspbian Buster Lite.
pi@raspberrypi:~ $ node --version
v10.18.0
pi@raspberrypi:~ $ npm --version
6.13.4
node red was installed using
I don't know where node-red.service came from, perhaps it came with the default raspbian install, but the one installed by the recommended script is nodered.service, so try
sudo systemctl start nodered
The error log from the system start version is limited to just a few lines and doesn't show what is actually causing the issue I don't think.
You will need to list more of the log. Something like sudo journalctl -u node-red -n 50 should do it I think.
The docs on the Pi page say to use it as a service to do
sudo systemctl enable nodered.service
Just to note that that command enables starting on boot, it does not actually start the service.
Yes and they also say to use
node-red-start
to manually start it
That is a good way of starting it as it starts the service and then shows the log, it is equivalent to something like
node-red-log
The fundamental problem that @tiagonmas has is probably that he is using the wrong service name, as I noted earlier.
Thanks! that was it.
I created the service definition based on a post on stackoverflow.
using the service you mention did the trick. THANKS
Don't forget to remove the one you created or you may get confused again in the future. :slight_smile:
