Node-red switching to pyhton 3 from pyhton2.7
I have both python 2.7 and python 3 installed on my system. Node red is using Python 2.7. Is there a way i can switch to python 3.
Solved: issue closed
it would be good if you can explain how you solved the issue, in case someone else searches the forum with the same question.
I had set the path in system variables and deleted the python 2.7 path to make things work for me.
