Hey. I am trying to run a object detection flow in the node red on mu raspberry pi 4, but my tfjs object detection node gives out his error message:
msg : error
"TypeError: Cannot read property 'whereImpl' of undefined"
Any suggestions on how to fix this issue? Thank you
Hi @TinkyLv
which node exactly are you trying to use? There are a few that use TFJS.
I've the same error using the IBM Tensorflow Object Detection package from
https://github.com/IBM/node-red-tensorflowjs
After reinstallation, checking all dependencies, etc. i've no more idea how to fix it.
The node does not connect to the model - doesnt matter if i give it the local path or leave it empty (where it should load the model from public sources according to the developer)
I run the package on a RPI 4 (updated and upgraded).
