Hello There !
I've been working for a couple of days on Node red on a Multitech Conduit AEP.
I really like this app, it's well designed and offers a lot of possibilities.
However, I've got some issues.
I tried to install node-red-contrib-postgres-multi and node-red-contrib-postgres-variable.
Second one was working fine but I didn't manage to get the first one to work properly.
I decided to remove them manually using npm on a ssh terminal.
Since then, those two nodes remains listed in my node palette and I can't find a way to get rid of them.
When launching the app on ssh term, here what I got :
npm bugs node-red
npm ERR! Linux 3.12.70
npm ERR! argv "node" "/usr/bin/npm" "bugs" "node-red"
npm ERR! node v0.10.48
npm ERR! npm v2.15.1
npm ERR! code ENOENT
npm ERR! errno ENOENT
npm ERR! syscall spawn
npm ERR! enoent spawn ENOENT
npm ERR! enoent This is most likely not a problem with npm itself
npm ERR! enoent and is related to npm not being able to find a file.
npm ERR! enoent
npm ERR! Please include the following file with any support request:
npm ERR! /opt/node-red/npm-debug.log
And the content of my npm-debug.log :
0 info it worked if it ends with ok
1 verbose cli [ 'node', '/usr/bin/npm', 'bugs', 'node-red' ]
2 info using npm@2.15.1
3 info using node@v0.10.48
4 silly mapToRegistry name node-red
5 silly mapToRegistry using default registry
6 silly mapToRegistry registry https://registry.npmjs.org/
7 silly mapToRegistry data { raw: 'node-red',
7 silly mapToRegistry scope: null,
7 silly mapToRegistry name: 'node-red',
7 silly mapToRegistry rawSpec: '',
7 silly mapToRegistry spec: 'latest',
7 silly mapToRegistry type: 'tag' }
8 silly mapToRegistry uri https://registry.npmjs.org/node-red
9 verbose request uri https://registry.npmjs.org/node-red/latest
10 verbose request no auth needed
11 info attempt registry request try #1 at 18:25:26
12 verbose request id 8d2227759010db10
13 http request GET https://registry.npmjs.org/node-red/latest
14 http 200 https://registry.npmjs.org/node-red/latest
15 verbose headers { date: 'Wed, 29 May 2019 14:24:26 GMT',
15 verbose headers 'content-type': 'application/json',
15 verbose headers 'transfer-encoding': 'chunked',
15 verbose headers connection: 'keep-alive',
15 verbose headers 'set-cookie': [ '__cfduid=d35a5857bd154c2bfd5c921b3ce06c2f81559139865; expires=Thu, 28-May-20 14:24:25 GMT; path=/; domain=.registry.npmjs.org; HttpOnly' ],
15 verbose headers 'content-encoding': 'gzip',
15 verbose headers 'cf-ray': '4de921c118d76966-CDG',
15 verbose headers 'expect-ct': 'max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"',
15 verbose headers vary: 'Accept-Encoding',
15 verbose headers server: 'cloudflare' }
16 silly get cb [ 200,
16 silly get { date: 'Wed, 29 May 2019 14:24:26 GMT',
16 silly get 'content-type': 'application/json',
16 silly get 'transfer-encoding': 'chunked',
16 silly get connection: 'keep-alive',
16 silly get 'set-cookie': [ '__cfduid=d35a5857bd154c2bfd5c921b3ce06c2f81559139865; expires=Thu, 28-May-20 14:24:25 GMT; path=/; domain=.registry.npmjs.org; HttpOnly' ],
16 silly get 'content-encoding': 'gzip',
16 silly get 'cf-ray': '4de921c118d76966-CDG',
16 silly get 'expect-ct': 'max-age=604800, report-uri="https://report-uri.cloudflare.com/cdn-cgi/beacon/expect-ct"',
16 silly get vary: 'Accept-Encoding',
16 silly get server: 'cloudflare' } ]
17 verbose get saving node-red to /home/root/.npm/registry.npmjs.org/node-red/latest/.cache.json
18 verbose correctMkdir /home/root/.npm correctMkdir not in flight; initializing
19 silly bugs url https://github.com/node-red/node-red/issues
20 verbose stack Error: spawn ENOENT
20 verbose stack at errnoException (child_process.js:1011:11)
20 verbose stack at Process.ChildProcess._handle.onexit (child_process.js:802:34)
21 verbose cwd /opt/node-red
22 error Linux 3.12.70
23 error argv "node" "/usr/bin/npm" "bugs" "node-red"
24 error node v0.10.48
25 error npm v2.15.1
26 error code ENOENT
27 error errno ENOENT
28 error syscall spawn
29 error enoent spawn ENOENT
29 error enoent This is most likely not a problem with npm itself
29 error enoent and is related to npm not being able to find a file.
30 verbose exit [ 1, true ]
I'm using a Multitech Conduit AEP, firmware 1.6.4, node-red v0.15.3
I'll modify my post if I missed anything.
Cheers
