Hi.
I have installed a NPM - node-red-contrib-sonoff-server.
After that it all crashed. When I start up it now just stops as listed below.
pi@raspberrypi:~ $ node-red
10 Feb 01:20:06 - [info]
Welcome to Node-RED
10 Feb 01:20:06 - [info] Node-RED version: v0.19.5
10 Feb 01:20:06 - [info] Node.js version: v10.15.1
10 Feb 01:20:06 - [info] Linux 4.14.97-v7+ arm LE
10 Feb 01:20:09 - [info] Loading palette nodes
10 Feb 01:20:25 - [info] Dashboard version 2.13.2 started at /ui
10 Feb 01:20:27 - [info] Settings file : /home/pi/.node-red/settings.js
10 Feb 01:20:27 - [info] Context store : 'default' [module=memory]
10 Feb 01:20:27 - [info] User directory : /home/pi/.node-red
10 Feb 01:20:27 - [warn] Projects disabled : editorTheme.projects.enabled=false
10 Feb 01:20:27 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.j son
your credentials.
10 Feb 01:20:27 - [info] Starting flows
10 Feb 01:20:27 - [info] [knx-controller:knx] connecting to knxjs server at 100. 0.0.160:3671 in mode[tunnel/unicast]
10 Feb 01:20:27 - [info] [knx-controller:knx] already connected to knxjs server at 100.0.0.160:3671 in mode[tunnel/unicast]
10 Feb 01:20:28 - [info] Started flows
10 Feb 01:20:28 - [info] [sonoff-server:910b980e.0b69d8] SONOFF Server Started O n Port 1080
10 Feb 01:20:28 - [red] Uncaught Exception:
10 Feb 01:20:28 - Error: listen EACCES: permission denied 0.0.0.0:443
at Server.setupListenHandle [as _listen2] (net.js:1260:19)
at listenInCluster (net.js:1325:12)
at Server.listen (net.js:1412:7)
at Server.listen (/home/pi/.node-red/node_modules/nodejs-websocket/Server.js :119:14)
at Object.module.exports.createServer (/home/pi/.node-red/node_modules/simpl e-sonoff-server/sonoff.server.module.js:263:8)
at new SonoffServer (/home/pi/.node-red/node_modules/node-red-contrib-sonoff -server/config-server/config-server.js:33:61)
at createNode (/usr/lib/node_modules/node-red/red/runtime/nodes/flows/Flow.j s:305:18)
at Flow.start (/usr/lib/node_modules/node-red/red/runtime/nodes/flows/Flow.j s:67:31)
at start (/usr/lib/node_modules/node-red/red/runtime/nodes/flows/index.js:32 8:29)
at tryCatchReject (/usr/lib/node_modules/node-red/node_modules/when/lib/make Promise.js:845:30)
at runContinuation1 (/usr/lib/node_modules/node-red/node_modules/when/lib/ma kePromise.js:804:4)
at Fulfilled.when (/usr/lib/node_modules/node-red/node_modules/when/lib/make Promise.js:592:4)
at Pending.run (/usr/lib/node_modules/node-red/node_modules/when/lib/makePro mise.js:483:13)
at Scheduler._drain (/usr/lib/node_modules/node-red/node_modules/when/lib/Sc heduler.js:62:19)
at Scheduler.drain (/usr/lib/node_modules/node-red/node_modules/when/lib/Sch eduler.js:27:9)
at process._tickCallback (internal/process/next_tick.js:61:11)
pi@raspberrypi:~ $
