This started happening yesterday, I think, but Node-RED won't start up anymore. It will start in safe mode, but I'm not even sure how to trace this error back to a particular node. I haven't added any new nodes in weeks, and the server has been restarted multiple times since then. Any pointers would be greatly appreciated!
Running in docker, FWIW.
Welcome to Node-RED
12 May 16:05:52 - [info] Node-RED version: v3.1.9
12 May 16:05:52 - [info] Node.js version: v16.20.2
12 May 16:05:52 - [info] Linux 5.15.0-105-generic x64 LE
12 May 16:05:53 - [info] Loading palette nodes
spawnSync locale ENOENT
12 May 16:05:54 - [info] Settings file : /data/settings.js
12 May 16:05:54 - [info] Context store : 'default' [module=memory]
12 May 16:05:54 - [info] User directory : /data
12 May 16:05:54 - [warn] Projects disabled : editorTheme.projects.enabled=false
12 May 16:05:54 - [info] Flows file : /data/flows.json
12 May 16:05:54 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
12 May 16:05:54 - [info] Starting flows
12 May 16:05:54 - [info] [hubitat config:d8fb523f.8f557] Starting endpoint for /hubitat/webhook
12 May 16:05:54 - [info] [hubitat config:378eb964.a79576] Starting endpoint for /hubitat/webhook_
12 May 16:05:54 - [info] [hue-bridge:Hue Bridge v2] Initializing the bridge (10.13.13.46)…
12 May 16:05:54 - [error] [mysql:MySQL DB] MySQL database not configured
12 May 16:05:54 - [error] [mysql:Logging DB] MySQL database not configured
12 May 16:05:54 - [info] BooleanLogicUltimate: Will create 2 dummy (false) values
12 May 16:05:54 - [info] Started flows
(node:7) Warning: Accessing non-existent property 'padLevels' of module exports inside circular dependency
(Use `node --trace-warnings ...` to show where the warning was created)
(node:7) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 uncaughtException listeners added to [process]. Use emitter.setMaxListeners() to increase limit
(node:7) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 opened listeners added to [WebSocketListenerNode]. Use emitter.setMaxListeners() to increase limit
(node:7) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 erro listeners added to [WebSocketListenerNode]. Use emitter.setMaxListeners() to increase limit
(node:7) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 closed listeners added to [WebSocketListenerNode]. Use emitter.setMaxListeners() to increase limit
12 May 16:05:54 - [info] [alexa-remote-account:477f784d.7be1a] intialising with the PROXY method and saved data...
12 May 16:05:54 - [info] [hubitat mode:Mode] Initialized. mode: Day
12 May 16:05:54 - [info] [hubitat mode:Current Mode] Initialized. mode: Day
12 May 16:05:54 - [info] [hubitat device:Input AppleTV] Initialized. switch: off
12 May 16:05:54 - [info] [hue-bridge:Hue Bridge v2] Connected to bridge
12 May 16:05:54 - [red] Uncaught Exception:
12 May 16:05:54 - [error] TypeError [ERR_INVALID_CALLBACK]: Callback must be a function. Received undefined
at makeCallback (node:fs:190:3)
at Object.unlink (node:fs:1751:14)
at compressFile (/data/node_modules/winston/lib/winston/transports/file.js:533:12)
at createAndFlush (/data/node_modules/winston/lib/winston/transports/file.js:521:7)
at /data/node_modules/winston/lib/winston/transports/file.js:543:16
at FSReqCallback.oncomplete (node:fs:202:21)
