Node red wont start - INFO: Service Node-RED exited with code 1 (by signal 0)
My Error Log below:
I HAVE A FEELING IT HAS SOMETHING TO DO WITH THIS NODE NOT BEING SETUP CORRECTLY. Node Red would not deploy the node when I was editing it. I run Node Red on a Homesassistant Blue Odroid N2+
1 Apr 16:47:01 - [red] Uncaught Exception:
1 Apr 16:47:01 - [error] Error: Invalid username
at Client.connect (/config/node_modules/ssh2/lib/client.js:203:13)
at _connectClient (/config/node_modules/@jorgelserve/node-red-contrib-ssh-v3/ssh.js:56:21)
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 17.0.11
You are running the latest version of this add-on.
System: Home Assistant OS 12.1 (aarch64 / odroid-n2)
Home Assistant Core: 2024.3.3
Home Assistant Supervisor: 2024.03.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
s6-rc: info: service init-nginx successfully started
up to date, audited 390 packages in 4s
69 packages are looking for funding
run npm fund for details
18 vulnerabilities (17 moderate, 1 critical)
To address issues that do not require attention, run:
npm audit fix
To address all issues possible (including breaking changes), run:
npm audit fix --force
Some issues need review, and may require choosing
a different dependency.
Run npm audit for details.
npm notice
npm notice New minor version of npm available! 10.2.4 -> 10.5.0
npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.5.0
npm notice Run npm install -g npm@10.5.0 to update!
npm notice
s6-rc: info: service init-nodered successfully started
s6-rc: info: service nodered: starting
s6-rc: info: service nodered successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[16:46:52] INFO: Starting Node-RED...
start
node $NODE_OPTIONS node_modules/node-red/red.js --settings /etc/node-red/config.js
1 Apr 16:46:54 - [info]
Welcome to Node-RED
1 Apr 16:46:54 - [info] Node-RED version: v3.1.8
1 Apr 16:46:54 - [info] Node.js version: v18.19.1
1 Apr 16:46:54 - [info] Linux 6.6.20-haos arm64 LE
1 Apr 16:46:55 - [info] Loading palette nodes
1 Apr 16:46:55 - [info] Node-RED Contrib Theme Collection version: v3.1.11
1 Apr 16:46:58 - [info] Dashboard version 3.6.5 started at /endpoint/ui
1 Apr 16:47:00 - [info] Settings file : /etc/node-red/config.js
1 Apr 16:47:00 - [info] Context store : 'default' [module=memory]
1 Apr 16:47:00 - [info] User directory : /config/
1 Apr 16:47:00 - [warn] Projects disabled : editorTheme.projects.enabled=false
1 Apr 16:47:00 - [info] Flows file : /config/flows.json
1 Apr 16:47:00 - [info] Server now running at http://127.0.0.1:46836/
[16:47:00] INFO: Starting NGinx...
1 Apr 16:47:00 - [info] Starting flows
1 Apr 16:47:01 - [error] [persist-store:62c146efef17dd2b] /home/Node-RED/persistance.json: ENOENT: no such file or directory, open '/home/Node-RED/persistance.json'
1 Apr 16:47:01 - [error] [persist-store:42dd5cc5.694f1c] /home/Node-RED/persistance.json: ENOENT: no such file or directory, open '/home/Node-RED/persistance.json'
1 Apr 16:47:01 - [info] [tcp in:1da40daa7ab33221] connecting to 192.168.1.72:23
1 Apr 16:47:01 - [warn] [RED.events] Deprecated use of "nodes-started" event from "/config/node_modules/node-red-contrib-persist/persist.js:164:20". Use "flows:started" instead.
1 Apr 16:47:01 - [error] [trigger-state:200c386fe013d6ce] ConfigError: trigger-state.error.enttity_id_required
1 Apr 16:47:01 - [info] Started flows
[16:47:01] INFO: Service Node-RED exited with code 1 (by signal 0)
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service nginx: stopping
[16:47:01] INFO: Service NGINX exited with code 0 (by signal 0)
s6-rc: info: service nginx successfully stopped
s6-rc: info: service init-nginx: stopping
s6-rc: info: service nodered: stopping
s6-rc: info: service init-nginx successfully stopped
s6-rc: info: service nodered successfully stopped
s6-rc: info: service init-nodered: stopping
s6-rc: info: service init-nodered successfully stopped
s6-rc: info: service init-customizations: stopping
s6-rc: info: service init-customizations successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
  • Restarting Home Assistant did not work
  • Power Cycling my Home Assistant Blue did not work
OK... I managed to fix this by starting Node Red in Safe Mode.
I deleted the node that was not setup correctly and it is all working again now.
Anyone who has the same problem...
  • Select Safe Mode from the configuration menu.
  • The flows will load but not started
  • Make repairs, then re-deploy the nodes.
