Node red write into postgres in other format
i got a node that insert a line into the database
INSERT INTO public."TB_ALERTE"("TR_SENSORNAME", "TR_INFO","TR_DATEHEURE") VALUES ( 'SENSOR/ TOILETTE' , 'ON','{{msg.payload}}');
the payload is coming from a function
const d = new Date();
msg.payload = d.toLocaleString();
but the problem is the value written in the db is not readable
6& #x2F;27& #x2F;2025, 10:36:23 AM
i put some space in the text because your website correct it
how can i be able to see the date like that
6/27/2025, 11:10:22 AM
thanks
Welcome to the forum @bobdion.
What datatype is your TR_DATEHEURE field?
For timestamp fields, since you are trying to store the current date/time, you could use the Progres current_timestamp function
So that would be something like
VALUES ( 'SENSOR/ TOILETTE' , 'ON', CURRENT_TIMESTAMP);
the field is a text not a timestamp
If you send the function node output to a debug node, what does it show?
I get this but of course my locale may be different to yours.
yes the result is good
Looks like the postgres Database or something else is converting special characters to Unicode Hex Character Code / (/).
Saying that you should store all timestamps in a database as universal time, and when you need to display read the universal time and convert to local time. This will cause you less issues further down the line.
ok but the problem will i get other problem like that with different function
there is a way to change that in postgres
Yes the unicode representation of / is /.
Postgres cannot store unicode, it needs utf-8 encoded strings.
It's not clear where the string gets unicode encoded.
Can you execute SHOW SERVER_ENCODING in Progres?
Which node-red config node are you using? Does the config allow an encoding setting?
i did what you say with current_timestamp
and its working
i will leave it like that and if in the future i got another problem i will come back here
lol
thanks
