Given:
msg.payload = 0
and
msg.menu exists thus:
{"1":"Show clock/time","2":"Show alarms","3":"Edit time/date","4":"Edit alarm/s","5":"Alarm run time"}
I have done things similar and done things like this before.
They work.
I'm not getting this.
So I have a function node with this code:
var starting = parseInt(msg.payload);
var ending = starting + 2 // set to 2 for now. Just to prove the code set at 2
//node.warn("Starting " + starting)
//node.warn("Ending " + ending)
//node.warn(msg.menu)
if (starting < ending)
pop()
return;
function pop() {
node.warn("Loop" + starting);
node.warn("Ending " + ending);
node.send(msg.menu[starting]);
starting +=1;
if (starting < ending){
pop()
Yeah, full of node.warn() stuff.
I'm not getting why the node.send(msg.menu[starting]); isn't working.
When the node.warn() line is active I see the structure.
And I am getting this as an error:
Function tried to send a message of type string
node.send needs to send an object, unless you configured the debug node to display something else. You are not sending an object, but a number eg. node.send({menu:starting}) - which in turn will output {menu:x}
Ideally, it should send one (two) of the entries.
Yes, I realised that 0 is not a good starting point.
So, that aside.... I am not getting why it is complaining.
I really am not getting these types.
(Some one shoot me)
Trying to de-construct it as much as I can:
var x = msg.menu[1];
node.warn("X " + x);
node.send(x);
var y = msg.menu[2];
node.warn("Y " + y);
node.send(y);
I get the X and Y messages shown to me.
So..... I'm not seeing the elephant.
Oh! So it has to be part of a message?
eg: node.send(msg.something)
That doesn't hold water because I tried to send msg.menu[1] and it didn't like it either.
You have to send a message Object.
You cannot send just a String.
So instead of doing
node.send(msg.menu[1]);
you need to wrap it in a message object:
node.send( { payload: msg.menu[1] })
One day I may remember all these structures.
Alas until then, sorry folks.
Nick: Thanks.
