Hi, I'm new here.
I used node-red for my balcony photovoltaic power plant.
I wanted to send the value of the power input to the house and the output of the photovoltaics to Thingspeak.com. For this operation I wanted to use "Node thingspeak42". When using it, a 301 error is returned.
I followed the example "https://www.youtube.com/watch?v=XGl1uFAveSI"
If the API Key value is not filled in, the same 301 error is returned.
Thanks for your help.
Otmar Hruska
Looking at the node's GitHub page shows that it has not been updated in 9 years. And there are unaddressed issues. Probably it does not work any more. You may need to find an alternative solution
Thanks for the help.
I've solved it.
Ota
It would be helpful if you could share your solution as that might help other people in the future.
You could also click the option that says 'Solution'.
Hi.
I'm really new here.
I'm looking for an automation solution for my balcony photovoltaic power plant. I have some "Victron" components, so the long-term statistical data is stored there.
But I wanted to be able to view more detailed data 24/7.
For this I can use a "Thingspeak" server.
The result will be something like this:....
Ota
----- Původní zpráva -----
(Attachment záznam-celé-obrazovky-06.11.2025-105612.bmp is missing)
Hi.
Ota
