Node to detect keyboard input?
Yes, I have searched the library, but not really had any luck.
There are some nodes which claim to do it, but I think are way too old.
I am looking for a node which will see keys pressed on the keyboard and send the result out as a message identifying the key pressed.
(Ideally I want to see a specific - variable as needed - key. But that is easy to get around with a switch node downstream from the node if it doesn't internally allow that.)
If you are using a Pi then the pi keyboard node should be there already. If not then maybe not.
I am using a RasPi.
No keyboard node installed.
Is that a standard node?
Yes it is part of the pi gpio node package we install with the install script
Strange.
So if I type keyboard in the palette search, I get no result.
I just searched the library and can't find it.
How would I install it?
node-red-node-pi-gpiod?
No. Just. node-red-node-pi-gpio
Perhaps you said no when it asked if you want the pi specific nodes.
Maybe. I have been known to make mistakes in the past - and will in the future too I guess.
