I needed to generate a random duration. Instead of developing it in a function node, I developed a small and simple node to accomplish this :
Your comments are very welcome ![]()
I am interested in the use case for a time duration in that format.
I use this node to generate a random duration in combination with the presencefaker and Sonos Plus nodes. This setup allows me to play an MP3 file that simulates presence with everyday life sounds. I want the track to start at a random point and be played only for a duration that is also random. This way, I can have sounds that are always different without having to manage playlists.
It's indeed a good idea to add the option to choose the output format.
Regards
I would have thought that you would want the duration in milliseconds or seconds for that, rather than as a string.
Hi, nop, the Sonos Plus node needs a string in HH:mm:ss.
I just update the node to select the wanted format (including milliseconds and seconds)
I find that very strange.
Maybe, but here : A.1 Universal Node · hklages/node-red-contrib-sonos-plus Wiki · GitHub
I was not doubting what you said, just commenting that it is surprising not to at least give the option of a duration in seconds.
Maybe because it is more easy to manipulate music with this format, as it is more humanly understable ![]()
