Nodered cannot be started after instal via Podman
I have installed the nodered via podman via below procedure and tried to start nodered and got below error. Do you have any suggestion?
https://catalog.redhat.com/software/containers/ibm-edge/node-red/5ecf8c35ecb5246c0903fb58?architecture=amd64&image=6023b851dd19c719155f3379)
podman pull registry.connect.redhat.com/ibm-edge/node-red:v0.0.3
podman run -it -p 1880:1880 -v node_red_data:/data --name mynodered ibm-edge/node-red
registry.connect.redhat.com/ibm-edge/node-red:v0.0.3 6 days ago Exited (0) 27 hours ago 0.0.0.0:1880->1880/tcp mynodered
Error;
node-red-docker@1.2.8 start /usr/src/node-red
node $NODE_OPTIONS node_modules/node-red/red.js $FLOWS "--settings" "/data/usr/conf/settings.js"
Error loading settings file: /data/usr/conf/settings.js
You're following a 4 years old operator deployment process, and there's no need to install node-red using an operator.
You can follow this simple process instead:
My OS is red hat Linux not openshift
