Is there any way to retain the context data written to "file", when switching between different projects.
I uncheck the "Clear Context when switching projects" setting, however, Nodered physically deletes the context folder from my harddrive, whenever a new Project is opened.
The context is retained, when restarting the server, or the nodered service itself.
Edit:
Nodered deletes all context related to the flow, but retains the global context, when switching between different projects. So as long as I use global.get and global.set, instead of context.set or flow.set, the flow works as intended.
I've just reproduced it in 3.0.1 so I went back to 2.2.2 and then to 2.0.0 (which did not have the check box) and the issue is in both of them also.
Shortly after you switch to a new project, the folder for the flow variables in the context folder is deleted. I could identify which folder it was by going to the project folder and looking at the id in the json file of the flow.
One other thing, when you do uncheck the checkbox it does not remain unchecked.
Just to repeat what I said on GitHub - 2.0.0 does not contain this issue because 2.0.0 did not give you the option to have context maintained when switching projects - it would always clear context as that was the well-defined and intended behaviour.
The issue here is whether the newly added feature to disable the clearing of context is being properly honoured in the File Context plugin.
