NodeRed in Home Assistant no longer can install pallets or update, seems to be offline. npm ERR! network 'proxy' config is set properly
I have Node Red Plugin v14 (or 3.0.2) installed in Home Assistant (Home Assistant 2022.12.8 Supervisor 2022.12.1 Operating System 9.4 Frontend 20221213.1 - latest on a pi400). I first noticed when my telegram pallet stopped sending or receiving messages that something was amiss. I seem also no longer be able to update any pallets, for example:
2022-12-30T12:54:32.859Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-telegrambot@14.8.7
2022-12-30T12:54:35.252Z [err] npm WARN config production Use `--omit=dev` instead.
2022-12-30T13:02:16.599Z [err] npm
2022-12-30T13:02:16.599Z [err]  ERR! code ETIMEDOUT
2022-12-30T13:02:16.600Z [err] npm
2022-12-30T13:02:16.600Z [err] ERR!
2022-12-30T13:02:16.601Z [err]  syscall connect
2022-12-30T13:02:16.601Z [err] npm ERR!
2022-12-30T13:02:16.602Z [err] errno
2022-12-30T13:02:16.602Z [err]  ETIMEDOUT
2022-12-30T13:02:16.612Z [err] npm ERR! network
2022-12-30T13:02:16.612Z [err]  request to https://registry.npmjs.org/node-red-contrib-telegrambot failed, reason: connect ETIMEDOUT 2606:4700::6810:1023:443
2022-12-30T13:02:16.613Z [err]  This is a problem related to network connectivity.
2022-12-30T13:02:16.613Z [err] npm ERR! network In most cases you are behind a proxy or have bad network settings.
2022-12-30T13:02:16.613Z [err] ERR! network
2022-12-30T13:02:16.614Z [err] network If you are behind a proxy, please make sure that the
2022-12-30T13:02:16.614Z [err] npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
2022-12-30T13:02:16.621Z [err]
2022-12-30T13:02:16.621Z [err] npm ERR!
2022-12-30T13:02:16.621Z [err]  A complete log of this run can be found in:
2022-12-30T13:02:16.621Z [err] npm ERR!     /root/.npm/_logs/2022-12-30T12_54_35_018Z-debug-0.log
2022-12-30T13:02:16.646Z rc=1
I tried, to reinstall the node red plugin in Home Assistant but that did not do the trick. Automations still work. thanks for any help
You may need to ask on the HA forum. Most of us don't use it and it installs node-red in some inscrutable fashion it seems.
I think you are right. I just did. thanks
That suggests it may be an IPV4/IPV6 issue. Do let us know when you find the solution, in case others report similar issues.
