I am using the Hue switch node from node-red-contrib-huemagic wired straight into a debug node to capture responses. At most the node will send responses with a significant delay if any. I have configured the switch on the bridge to turn on/off one light and the bridge acts immediately.
Using the Light node I can capture the lights response. While with delays, I can get the light state reliably.
The current behavior makes it impossible to use Hue switches in node red to control as in my case a mqqt message.
The question I have, is this just me or are the hue nodes generally acting with significant delays? I am keen to hear from anyone who is using Hue switches via node red.
Thanks. I tried it and it did not solve the issue.
I did had a look at the logs and found these:
31 Oct 07:06:33 - [debug] [hue-bridge:Philips hue] TypeError: Cannot read property 'lastUpdated' of undefined
at HueBridge.getUpdates (/home/pi/.node-red/node_modules/node-red-contrib-huemagic/red/hue-bridge-config.js:120:34)
at scope.client.rules.getAll.then.then.results (/home/pi/.node-red/node_modules/node-red-contrib-huemagic/red/hue-bridge-config.js:59:31)
at process._tickCallback (internal/process/next_tick.js:68:7)
31 Oct 07:06:34 - [debug] [hue-bridge:Philips hue] TypeError: Cannot read property 'lastUpdated' of undefined
I have no issues with any other devices than sensors (switches, motion). Poll time has been reduced. Everything else works fine.
The delay is massive and messages are not reliable. So far that it is not usable.
Openhab is working fine. My plan was to replace Openhab with NodeRed but this is off the table now.
If you have checked the recommended nodejs version in the ReadMe and that you have the latest version of the node, you can open an issue on the nodes page on github to communicate directly with the nodes author
Good point. It is a fresh install using the NodeRed recommended approach, so I assume it is the latest.
I checked on GitHub after I posted here and someone already raised an issue. I was curious if anyone else is seeing the same. I now know I am not alone.
That would give you the latest version of Node-RED, to see if you have the latest version of the node you can check in the “Manage palette” option in the menu
