i like to get from this the yellow fields the value into a new node
how do i split this into separate values via json?
how do i do that i missing some json understanding
Hi @MHagreis
this section of the docs describes how you can identify the path to any element of a message - Working with messages : Node-RED
Using what those docs say, you'll find you can access some of your highlighted properties as msg.payload[0][0].subsystem and msg.payload[0][0].num_user for the first two, and msg.payload[0][3].subsystem and msg.payload[0][3].num_user for the second two.
What you do from there will depend on how you want to use those values.
Thanks solved and now i am getting the logic as wel
(a bit less noob)
There is another way to extract bits from a JSON object structure, using the JSONata expression syntax of the change node. Just as a teaser, here is an expression that retrieves just those 2 fields from an array of objects:
payload.*.{
"subsystem": subsystem,
"num_user": num_user
Head over to try.jsonata.org for more info -- and to experiment with your own data.
