i hope you mean that:
[{"id":"41cc7a8d.3919e4","type":"tab","label":"Flow 3","disabled":false,"info":""},{"id":"48eae479.82f56c","type":"serial in","z":"41cc7a8d.3919e4","name":"","serial":"a09a02e6.22d38","x":70,"y":180,"wires":[["80060cef.bb6e2","53c46c2.11c3294"]]},{"id":"8b221541.41f188","type":"function","z":"41cc7a8d.3919e4","name":"temp","func":"var temp1= msg.payload[6]-48;\nvar temp2= msg.payload[7]-48;\nvar temp3= msg.payload[9]-48;\nvar temp4= msg.payload[10]-48;\nvar result = (temp1*1000)+ (temp2*100) + (temp3*10) + temp4; \nresult = result/100;\nvar result1 = {payload:result};\nreturn[result1];","outputs":1,"noerr":0,"initialize":"","finalize":"","x":170,"y":700,"wires":[[]]},{"id":"274f5616.2fd32a","type":"function","z":"41cc7a8d.3919e4","name":"humidity","func":"var hum1= msg.payload[0]-48;\nvar hum2= msg.payload[1]-48;\nvar hum3= msg.payload[3]-48;\nvar hum4= msg.payload[4]-48;\nvar result = (hum1*1000)+ (hum2*100) + (hum3*10) + hum4;\nresult = result/100;\nvar result1 = {payload:result};\nreturn[result1];","outputs":1,"noerr":0,"initialize":"","finalize":"","x":160,"y":860,"wires":[[]]},{"id":"6951fd8b.107fc4","type":"function","z":"41cc7a8d.3919e4","name":"water level value","func":"var waterlevelValue1= msg.payload[0]-48;\nvar waterlevelValue2= msg.payload[1]-48;\nvar waterlevelValue3= msg.payload[3]-48;\nvar waterlevelValue4= msg.payload[4]-48;\nvar result = (waterlevelValue1*1000)+ (waterlevelValue2*100) + (waterlevelValue3*10) + waterlevelValue4;\nresult = result/100;\nvar result1 = {payload:result};\nreturn[result1];","outputs":1,"noerr":0,"initialize":"","finalize":"","x":190,"y":780,"wires":[[]]},{"id":"4555a817.50f388","type":"function","z":"41cc7a8d.3919e4","name":"","func":"msg.payload = {\"t\":msg.payload};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":80,"y":580,"wires":[[]]},{"id":"b94885ff.74eee8","type":"function","z":"41cc7a8d.3919e4","name":"","func":"msg.payload = {\"mmwaterValue\":msg3};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":720,"y":460,"wires":[[]]},{"id":"15436bcc.f153d4","type":"mobius azureiothub","z":"41cc7a8d.3919e4","hubid":"","scopeid":"","deviceid":"","primarykey":"","connectTo":"iotHub","connectionString":"HostName=EarlyWarning.azure-devices.net;DeviceId=Arduino;SharedAccessKey=RYeksPH8lCkEjXeiggmZKr/Vginbu4zhl/iQUiiXuHY=","name":"","x":560,"y":660,"wires":[[]]},{"id":"235150c.c42b2b","type":"ui_gauge","z":"41cc7a8d.3919e4","name":"","group":"d5da3e9b.46abf","order":0,"width":0,"height":0,"gtype":"gage","title":"temp","label":"units","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":510,"y":620,"wires":[]},{"id":"f9704501.d13ea8","type":"ui_gauge","z":"41cc7a8d.3919e4","name":"","group":"d5da3e9b.46abf","order":2,"width":0,"height":0,"gtype":"gage","title":"water level","label":"units","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":350,"y":660,"wires":[]},{"id":"1755e7d9.0a3ea8","type":"ui_gauge","z":"41cc7a8d.3919e4","name":"","group":"d5da3e9b.46abf","order":1,"width":0,"height":0,"gtype":"gage","title":"humidity","label":"units","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":520,"y":580,"wires":[]},{"id":"e111a407.33b718","type":"function","z":"41cc7a8d.3919e4","name":"","func":"msg.payload = {\"h\":msg.payload};\nreturn msg;","outputs":1,"noerr":0,"initialize":"\n","finalize":"","x":80,"y":660,"wires":[[]]},{"id":"c9b9f8e1.ce31c8","type":"buffer-maker","z":"41cc7a8d.3919e4","name":"","specification":"spec","specificationType":"ui","items":[{"name":"humidity","type":"uint8","length":1,"dataType":"jsonata","data":"payload"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","x":410,"y":720,"wires":[[]],"info":"msg.payload = {\"humidity\":msg.payload};\nreturn msg;"},{"id":"a28547b4.ebb428","type":"buffer-parser","z":"41cc7a8d.3919e4","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"uint8","name":"item1","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":430,"y":800,"wires":[[]]},{"id":"27fb195d.0a6db6","type":"json","z":"41cc7a8d.3919e4","name":"","property":"payload.temp","action":"str","pretty":true,"x":210,"y":620,"wires":[[]],"info":"msg.payload = {\"temp\":msg.payload};\nreturn msg;"},{"id":"4a87d288.fb65cc","type":"json","z":"41cc7a8d.3919e4","name":"","property":"payload.humidity","action":"str","pretty":true,"x":210,"y":540,"wires":[[]],"info":"msg.payload = {\"humidity\":msg.payload};\nreturn msg;"},{"id":"5c32be48.09539","type":"json","z":"41cc7a8d.3919e4","name":"","property":"payload.mmwaterValue","action":"str","pretty":true,"x":210,"y":580,"wires":[[]],"info":"msg.payload = {\"mmwaterValue\":msg.payload};\nreturn msg;"},{"id":"13e4b411.b658bc","type":"delay","z":"41cc7a8d.3919e4","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":340,"y":620,"wires":[[]]},{"id":"e0de248e.141398","type":"change","z":"41cc7a8d.3919e4","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"msg.payload.temp","fromt":"str","to":"msg.payload","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":760,"y":540,"wires":[[]]},{"id":"9343e80e.6933b8","type":"split","z":"41cc7a8d.3919e4","name":"","splt":"1\\n","spltType":"len","arraySplt":"1","arraySpltType":"len","stream":true,"addname":"","x":330,"y":500,"wires":[[]]},{"id":"95b58812.c31348","type":"function","z":"41cc7a8d.3919e4","name":"","func":"msg.payload = {\"data\":msg.payload};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":380,"y":860,"wires":[[]]},{"id":"40baec5.060d914","type":"function","z":"41cc7a8d.3919e4","name":"","func":"msg = JSON.parse(msg.payload);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":80,"y":540,"wires":[[]]},{"id":"4539c79a.67e308","type":"switch","z":"41cc7a8d.3919e4","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":210,"y":500,"wires":[[]],"info":"switch (msg.payload)\n{\n case \"1\":\n if (msg.payload = {\"temp\":msg.paload})\n return msg;\n break;\n case \"2\":\n if (msg.payload = {\"humidity\":msg.paload})\n return msg;\n break;\n case \"3\":\n if (msg.payload = {\"mmwaterValue\":msg.paload})\n return msg;\n}"},{"id":"617348fa.76af98","type":"function","z":"41cc7a8d.3919e4","name":"","func":"var msg1 = { payload: {\n device: msg.payload.dev_id,\n temp: msg.payload.payload_fields.temp\n \n }\n}\nvar msg2= { payload : {\n device: msg.payload.dev_id,\n humidity: msg.payload.payload_fields.humidity\n }\n}\nvar msg3 = { payload : {\n device: msg.payload.dev_id,\n mmwaterValue: msg.payload.payload_fields.mmwaterValue\n }\n}\n\nreturn [msg1, msg2, msg3];\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":340,"y":580,"wires":[[]]},{"id":"a75aa48d.b3cd18","type":"function","z":"41cc7a8d.3919e4","name":"","func":"Var = Number(msg.payload)\nif (Var>20 && Var<45)\nmsg.payload = {\"temp\": Var};\nif (Var>=45)\nmsg.payload = {\"humidity\": Var};\nif (Var>=0 && Var<20)\nmsg.payload = {\"mmwaterValue\": Var};\nreturn Var;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":340,"y":540,"wires":[[]]},{"id":"99a2990a.6017c8","type":"change","z":"41cc7a8d.3919e4","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"payload.temp","fromt":"msg","to":"payload.temp","tot":"msg"},{"t":"change","p":"payload","pt":"msg","from":"payload.humidity","fromt":"msg","to":"payload.humidity","tot":"msg"},{"t":"change","p":"payload","pt":"msg","from":"payload.mmwaterValue","fromt":"msg","to":"payload.mmwaterValue","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":460,"wires":[[]]},{"id":"afe7da6b.2fd628","type":"Split Threshold","z":"41cc7a8d.3919e4","name":"","property":"payload.temp","startCompare":">=","startValue":20,"stopCompare":"<","stopValue":45,"duration":60,"durationUnit":"seconds","payload":"msg.payload.temp","payloadType":"json","handling":"all","each":"topic","persistMode":true,"aggressiveMode":false,"x":540,"y":540,"wires":[[]]},{"id":"5ee89332.69924c","type":"Split Threshold","z":"41cc7a8d.3919e4","name":"","property":"payload.humidity","startCompare":">=","startValue":23,"stopCompare":"<","stopValue":100,"duration":60,"durationUnit":"seconds","payload":"msg.payload.humidity","payloadType":"json","handling":"all","each":"topic","persistMode":true,"aggressiveMode":false,"x":540,"y":500,"wires":[[]]},{"id":"5617b6b.1f95f48","type":"Split Threshold","z":"41cc7a8d.3919e4","name":"","property":"payload.mmwaterValue","startCompare":">=","startValue":0,"stopCompare":"<","stopValue":5,"duration":60,"durationUnit":"seconds","payload":"msg.payload.mmwaterValue","payloadType":"json","handling":"all","each":"topic","persistMode":true,"aggressiveMode":false,"x":540,"y":460,"wires":[[]]},{"id":"242cbfa6.fe0f8","type":"function","z":"41cc7a8d.3919e4","name":"","func":"msg.payload= Number(msg.payload)\nif (msg.payload>20 && msg.payload<45)\nmsg.payload = {\"temp\":msg.payload};\nif (msg.payload>=45)\nmsg.payload = {\"humidity\":msg.payload};\nif (msg.payload>=0 && msg.payload<20)\nmsg.payload = {\"mmwaterValue\":msg.payload};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":80,"y":620,"wires":[[]]},{"id":"ca5e8bc7.33e968","type":"split","z":"41cc7a8d.3919e4","name":"","splt":"3\\n","spltType":"len","arraySplt":"3","arraySpltType":"len","stream":true,"addname":"","x":210,"y":660,"wires":[[]],"info":"data= Number(data)\nif (data>20 && data<45)\ndata = {\"temp\":data};\nif (data>=45)\ndata = {\"humidity\":data};\nif (data>=0 && data<20)\ndata = {\"mmwaterValue\":data};\nreturn data;"},{"id":"7e256050.c6ec9","type":"split","z":"41cc7a8d.3919e4","name":"","splt":"1\\n","spltType":"len","arraySplt":"1","arraySpltType":"len","stream":true,"addname":"","x":210,"y":460,"wires":[[]]},{"id":"92dc741a.aef448","type":"function","z":"41cc7a8d.3919e4","name":"","func":"var test = msg.payload;\ntag1 = {payload:test.temp[0].v};\ntag2 = {payload:test.humidity[1].v};\ntag3 = {payload:test.mmwaterValue[2].v};\nreturn [tag1,tag2,tag3];","outputs":1,"noerr":0,"initialize":"","finalize":"","x":80,"y":500,"wires":[[]]},{"id":"a91868c7.2d3368","type":"function","z":"41cc7a8d.3919e4","name":"","func":"var pl = msg.payload.trim();\nif(!pl) return null;\nvar parts = pl.trim().split(\",\");\nif(parts.length < 3) return null;\nvar msg1 = {\n topic: \"humidity\",\n payload: Number(parts[0])\n}\nvar msg2 = {\n topic: \"temperature\",\n payload: Number(parts[1])\n}\nvar msg3 = {\n topic: \"water\",\n payload: Number(parts[2])\n}\nreturn [[msg1, msg2, msg3]];","outputs":1,"noerr":0,"initialize":"","finalize":"","x":80,"y":460,"wires":[[]]},{"id":"80060cef.bb6e2","type":"function","z":"41cc7a8d.3919e4","name":"function LoRa","func":"var pl = msg.payload.trim();\nif(!pl) return null;\nvar parts = pl.split(\",\");\nif(parts.length < 3) return null;\n\nmsg.payload = {\n humidity: Number(parts[0]),\n temperature: Number(parts[1]),\n mmwaterValue: Number(parts[2])\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":340,"y":180,"wires":[["eb603aed.51e128","372cfca1.f56a74","c98e210f.88ff"]]},{"id":"eb603aed.51e128","type":"function","z":"41cc7a8d.3919e4","name":"Trigger Alarm","func":"var mmwaterValue=msg.payload;\nvar alarm_flag=context.get(\"alarm_flag\");\nif (typeof alarm_flag==\"undefined\")\nalarm_flag=false;\n\nif (mmwaterValue>3 && !alarm_flag)\n{\n node.warn(\"debug1 - mmwaterValue=\" + mmwaterValue);\n alarm_flag=true;\n msg.alarm=1;\n context.set(\"alarm_flag\",alarm_flag);\n return msg;\n}\nif (mmwaterValue<=3 && alarm_flag)\n{\n node.warn(\"debug1 - mmwaterValue=\" + mmwaterValue);\n alarm_flag=false;\n msg.alarm=0;\n context.set(\"alarm_flag\",alarm_flag);\n return msg;\n}\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":540,"y":320,"wires":[["372cfca1.f56a74","3d0a15e4.331e6a"]]},{"id":"372cfca1.f56a74","type":"function","z":"41cc7a8d.3919e4","name":"function email","func":"var mmwaterValue=msg.payload;\n\nvar d= new Date();\nvar message= \"\";\nif (msg.alarm==1)\n{ \n msg.topic=\"High water level Alarm\";\n message=\" High water level Alarm mmwaterValue= \";\n}\nelse\n{ \n message=\" Water level now normal mmwaterValue= \";\n msg.topic=\"Water level Alarm Reset\"\n}\nmsg.payload=\"time\" + d + message + msg.payload;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":640,"y":220,"wires":[["780f0cc1.6a1d94"]]},{"id":"2e4932cc.e055be","type":"email out","z":"41cc7a8d.3919e4","server":"smtp.gmail.com","port":"465","secure":true,"tls":true,"name":"alexandros2013@hotmail.com","dname":"","sendfailedcontrib":"","messagesentcontrib":"","x":790,"y":500,"wires":[[]]},{"id":"780f0cc1.6a1d94","type":"debug","z":"41cc7a8d.3919e4","name":"function email msg","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":930,"y":180,"wires":[]},{"id":"53c46c2.11c3294","type":"debug","z":"41cc7a8d.3919e4","name":"com5 msg","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":260,"y":100,"wires":[]},{"id":"c98e210f.88ff","type":"debug","z":"41cc7a8d.3919e4","name":"function LoRa msg","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":620,"y":120,"wires":[]},{"id":"3d0a15e4.331e6a","type":"debug","z":"41cc7a8d.3919e4","name":"trigger alarm msg","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":860,"y":320,"wires":[]},{"id":"a09a02e6.22d38","type":"serial-port","serialport":"COM2","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","waitfor":"","dtr":"none","rts":"none","cts":"none","dsr":"none","newline":"100","bin":"false","out":"time","addchar":"false","responsetimeout":""},{"id":"d5da3e9b.46abf","type":"ui_group","name":"DHT22","tab":"784aac14.5c2404","order":2,"disp":true,"width":"6","collapse":false},{"id":"784aac14.5c2404","type":"ui_tab","name":"Station","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
