Notification Margin
How to give left and right margin?
this happened after I updated ui-dashboard to version 3.2.3
Assuming you are using the notification node this works
msg.payload = `<!DOCTYPE html>
                <html><head>
                <title>Save Confirmation</title>
                </head>
                <body>
                   <div style = "padding: 0 0.5em 0 0.5em">
                      <p> Are you sure you want to save data? </p>
                   </div>
                </body>
                <style>
                   .md-title {
                       padding: 0 0.5em 0 0.5em;
                </style>
                </html>`;
[{"id":"dd715df23483c35a","type":"ui_toast","z":"cbf497889c72d4b4","position":"dialog","displayTime":"0","highlight":"","sendall":false,"outputs":1,"ok":"OK","cancel":"Cancel","raw":true,"className":"","topic":"Save Confirmation","name":"","x":1530,"y":940,"wires":[[]]},{"id":"f4d2d33726516220","type":"function","z":"cbf497889c72d4b4","name":"Format Payload for notification node","func":"msg.payload = `<!DOCTYPE html>\n                <html><head>\n                <title>Save Confirmation</title>\n                </head>\n                <body>\n                    <div style = \"padding: 0 0.5em 0 0.5em\">\n                        <p>Are you sure you want to save data?</p>\n                    </div>\n                </body>\n\n                <style>\n                    .md-title {\n                        padding: 0 0.5em 0 0.5em;\n                    }\n                </style>\n                </html>`;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1270,"y":940,"wires":[["dd715df23483c35a"]]},{"id":"bd7352d782113344","type":"inject","z":"cbf497889c72d4b4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1000,"y":940,"wires":[["f4d2d33726516220"]]}]
It's work, thank you
