In DB1 I used a button to send a "Are you sure" payload to notification node which had a Yes/No choice and sent out an appropriate payload. In DB2 this node is simply a dumb message. Is there an easy way to recreate this "are you sure" confirmation.
Yes:
Still learning vue, but something like this?
[{"id":"173ea41b0ea00884","type":"ui-template","z":"21423082d584a949","group":"","page":"","ui":"","name":"dialog","order":1,"width":0,"height":0,"head":"","format":"<template>\n <v-btn @click=\"showDialog()\">Hi!</v-btn>\n <v-dialog v-model=\"dialog\" max-width=\"500px\">\n <v-card>\n <v-card-title>click me!</v-card-title>\n <v-card-actions>\n <v-spacer></v-spacer>\n <v-btn @click=\"dialogResponse(true)\">True</v-btn>\n <v-btn @click=\"dialogResponse(false)\">False</v-btn>\n <v-spacer></v-spacer>\n </v-card-actions>\n </v-card>\n </v-dialog>\n</template>\n\n<script>\n export default {\n data() {\n return {\n dialog: false \n }\n },\n watch: {\n dialog(val) {\n val || this.close()\n },\n },\n computed: {},\n methods: {\n dialogResponse (val) {\n this.send({payload: val})\n this.dialog = false\n\n },\n showDialog() {\n this.dialog = true\n }\n },\n mounted() {},\n unmounted() {}\n }\n</script>\n","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":730,"y":640,"wires":[["edd9df0c75cc51f2"]]},{"id":"edd9df0c75cc51f2","type":"debug","z":"21423082d584a949","name":"debug 462","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":930,"y":640,"wires":[]}]
But you will need to install version 1.15.0 of the dashboard (released a few hours ago) to get the OK/Cancel feature.
I'm just starting with db2. Where is ui-notification as it's not on the db2 node list.
I have upgraded to 1.15.0
Still learning ?? Very good. perfect for me thanks
The ui-notification widget has always been there, it is just the confirm feature that has now been added.
