Hi everyone !
I am working on a project, and i have some problem ... I want to set a numeric input state to disable or enable with a switch but hold the value . Could someone help me?The saved value is stored on a file and load from there with the load/save button .... The method i want to use is working with the switch ui element ,but not with the input .
[{"id":"1de98200.aa1a7e","type":"file in","z":"f332f131.f2472","name":"","filename":"\\Users\\user\\.node-red\\data\\test.log","format":"lines","chunk":false,"sendError":false,"x":280,"y":180,"wires":[["37982fa.67cb4d"]]},{"id":"3d7161a8.175a9e","type":"inject","z":"f332f131.f2472","name":"LOAD LAST STATE","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":100,"wires":[["1de98200.aa1a7e"]]},{"id":"42bd7ec5.08603","type":"ui_button","z":"f332f131.f2472","name":"","group":"c5238e7d.2a1a","order":4,"width":"12","height":"1","passthru":false,"label":"Load ","tooltip":"previous Save","color":"","bgcolor":"","icon":"","payload":"true","payloadType":"bool","topic":"","x":130,"y":240,"wires":[["1de98200.aa1a7e"]]},{"id":"37982fa.67cb4d","type":"json","z":"f332f131.f2472","name":"","property":"payload","action":"","pretty":false,"x":530,"y":180,"wires":[["5ba8b736.eb25b8","eeff6a7e.31a7b8"]]},{"id":"5ba8b736.eb25b8","type":"change","z":"f332f131.f2472","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.6","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":720,"y":220,"wires":[["b84b7468.110108"]]},{"id":"b84b7468.110108","type":"ui_switch","z":"f332f131.f2472","name":"","label":"Auto mode","tooltip":"Off=manual,On =Auto","group":"c5238e7d.2a1a","order":1,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"auto","onvalueType":"str","onicon":"","oncolor":"","offvalue":"manual","offvalueType":"str","officon":"","offcolor":"","x":730,"y":300,"wires":[["95143eee.5a048"]]},{"id":"95143eee.5a048","type":"switch","z":"f332f131.f2472","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"auto","vt":"str"},{"t":"eq","v":"manual","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":870,"y":300,"wires":[["c845b1ca.6d95e","e04dc781.81b0f8"],["e8b8996b.e9b908","fc2e4fe9.b9fc3"]]},{"id":"c845b1ca.6d95e","type":"change","z":"f332f131.f2472","name":"Manual_en_f","rules":[{"t":"set","p":"enabled","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1030,"y":60,"wires":[[]]},{"id":"e8b8996b.e9b908","type":"change","z":"f332f131.f2472","name":"Manual_en_t","rules":[{"t":"set","p":"enabled","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1030,"y":100,"wires":[[]]},{"id":"e04dc781.81b0f8","type":"change","z":"f332f131.f2472","name":"Auto_en_t","rules":[{"t":"set","p":"enabled","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1040,"y":320,"wires":[["f266cb28.d99508"]]},{"id":"fc2e4fe9.b9fc3","type":"change","z":"f332f131.f2472","name":"Auto_en_f","rules":[{"t":"set","p":"enabled","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1040,"y":280,"wires":[["f266cb28.d99508"]]},{"id":"f266cb28.d99508","type":"ui_numeric","z":"f332f131.f2472","name":"","label":"Temperature:","tooltip":"","group":"829d8d43.00e61","order":0,"width":0,"height":0,"passthru":true,"topic":"","format":"{{value}} °","min":"-20","max":"50","step":1,"x":1190,"y":160,"wires":[["25c06473.8dd63c"]]},{"id":"eeff6a7e.31a7b8","type":"change","z":"f332f131.f2472","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.7","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":720,"y":160,"wires":[["f266cb28.d99508"]]},{"id":"25c06473.8dd63c","type":"change","z":"f332f131.f2472","name":"","rules":[{"t":"set","p":"Data.7","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1430,"y":160,"wires":[[]]},{"id":"8a80c398.e75f","type":"ui_button","z":"f332f131.f2472","name":"","group":"c5238e7d.2a1a","order":3,"width":"12","height":"1","passthru":false,"label":"Save","tooltip":"","color":"","bgcolor":"","icon":"","payload":"true","payloadType":"bool","topic":"","x":110,"y":540,"wires":[["c204ad26.afd74"]]},{"id":"7fb2fdfc.5c7da4","type":"file","z":"f332f131.f2472","name":"","filename":"\\Users\\user\\.node-red\\data\\test.log","appendNewline":false,"createDir":false,"overwriteFile":"true","x":560,"y":460,"wires":[[]]},{"id":"2e8e95b8.4b140a","type":"json","z":"f332f131.f2472","name":"","property":"payload","action":"","pretty":false,"x":330,"y":460,"wires":[["7fb2fdfc.5c7da4","7897386b.1e4348"]]},{"id":"c204ad26.afd74","type":"function","z":"f332f131.f2472","name":"","func":"var msg={};\nmsg.payload=global.get(\"Data\");\nreturn msg;","outputs":1,"noerr":0,"x":190,"y":460,"wires":[["2e8e95b8.4b140a"]]},{"id":"8fd8dec7.15476","type":"inject","z":"f332f131.f2472","name":"SAVE CURRENT STATE","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":190,"y":380,"wires":[["c204ad26.afd74"]]},{"id":"7897386b.1e4348","type":"debug","z":"f332f131.f2472","name":"SAVE","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":490,"y":520,"wires":[]},{"id":"c5238e7d.2a1a","type":"ui_group","z":"","name":"MANUAL/AUTO","tab":"52b04880.62c1d8","order":1,"disp":false,"width":"24","collapse":false},{"id":"829d8d43.00e61","type":"ui_group","z":"","name":"Auto Controll","tab":"52b04880.62c1d8","order":4,"disp":true,"width":"6","collapse":false},{"id":"52b04880.62c1d8","type":"ui_tab","z":"","name":"Control","icon":"dashboard","order":3,"disabled":false,"hidden":false}]
I modified the code what was in the first comment to be simply .Could someone give me some help about it? I have no ide how to solve it ...
