OAUTH2 Authentication with authentik
Howdy, it has been a while - work has been busy.
Have been having a play with my home set up and for fun looking at using authentik as the SSO for my home lab. I am learning on the fly here so probably have made a silly mistake
Was pleasantly surprised that they support Node Red oauth2
Have followed the instructions found here
installed the passport-openidconnect package and updated settings.js
with
adminAuth: {
type:"strategy",
strategy: {
        label: 'Sign in with authentik',
        icon:"fa-cloud",
        strategy: require("passport-openidconnect").Strategy,
        options: {
                issuer: 'https://authentik.xxxx.com/application/o/nodered-slug/',
                authorizationURL: 'https://authentik.xxxx.com/application/o/authorize/',
                tokenURL: 'https://authentik.xxxxx.com/application/o/token/',
                userInfoURL: 'https://authentik.xxxx.com/application/o/userinfo/',
                clientID: 'clientIsRedacted',
                clientSecret: 'clientSecretIsRedacted',
                callbackURL: 'https://nr.xxxx.com/auth/strategy/callback/',
                scope: ['email', 'profile', 'openid'],
                proxy: true,
        verify: function(issuer, profile, done) {
                done(null, profile)
    users: function(user) {
        return Promise.resolve({ username: user, permissions: "*" });
The authentication appears to work (logs form authentik ) however getting a ENOTFOUD on the return to node red. There is nothing in any logs
A hope that someone may have see something similar
Hey I wrote that guide, hopefully I can be of help. I've not seen the ENOTFOUD error before.
Have you changed the logging level in your settings.js yet?
    // Configure the logging output
    logging: {
        console: {
            level: "trace",
            metrics: true,
            audit: true
Oh also in Authentik go to Admin Interface -> Providers -> Node-RED and verify the URL's:
  1. OpenID Configuration Issuer -> issuer:
  2. Authorize URL -> authorizationURL:
  3. Token URL -> tokenURL:
  4. Userinfo URL -> userInfoURL:
Heh,
thanks for the quick reply. As I was checking I attempted to ping the authentik host from the nr container, and guess what I can't. It looks like an issue with dns in docker when running a dns host (pi hole) on the same host. Alas it is to late to night to diagnose but for tomorrow
BTW thanks for the doco and support
So hacked the hosts file so it resolves and all good - proper soln tomorrow
For the record - google was not a great help here. The commonly suggested soln (adding the explicit ip to the port definition in pihole) did not work for me, however adding a explicit dns record in the node-red service of the docker compose file worked.
For anyone who has a similar issue
dns:
    - 192.168.2.50
Thx again
