Object export from Messages
Hello and good day, I'm still at the beginning with NodeRed. I would like to extract all values ​​from an Object, then I would like to write these values ​​into a Influx Database.
Which node can or must use for the extract the Paramters from the Objekt?
I have test it with the Splitt and Switch,
but it did not work out as I had hoped.
Bildschirmfoto 2019-12-11 um 15.52.44|432x499
Please read the documentation.
Thanks, but I had already seen that and it did not help me.
That’s strange. How did you end up with the switch node and the split node?
I've just tried a bit, I miss so little practical examples in the documentary.
then I just don’t try it out a bit, I thought that wouldn’t be a big deal. Sorry i must translate with google. :blush:
