I have a flow that works as it should, however sometimes the motion detector doesn't detect...
The motion detector is an Eve motion sensor that then triggers a NR homekit switch, which then triggers the flow. I am thinking about adding a second motion sensor to the room. Haven't done it yet, just a concept so far so I'm trying to figure out how to integrate it into the flow.
What I'm thinking so far is to have the second motion sensor actuate a second dummy switch...
So would it be as easy, using the flow, as having both switches flow into the same series?
Am I making sense? Should I just wait until I purchase the sensor to try it out?
"id": "68bdf802.773ca8",
"type": "tab",
"label": "Bedroom Occupancy",
"disabled": false,
"info": ""
"id": "56d28fa8.491c1",
"type": "switch",
"z": "68bdf802.773ca8",
"name": "Occupied",
"property": "payload.On",
"propertyType": "msg",
"rules": [
"t": "eq",
"v": "true",
"vt": "jsonata"
"t": "eq",
"v": "false",
"vt": "jsonata"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 600,
"y": 180,
"d8aa7de5.7c546",
"64472eb1.62606"
"d8aa7de5.7c546"
"id": "7ac14fb9.11fb7",
"type": "homekit-service",
"isParent": true,
"hostType": "0",
"bridge": "480b5cc0.4ea614",
"accessoryId": "",
"parentService": "",
"name": "Bedroom Occupied",
"serviceName": "Switch",
"topic": "",
"filter": false,
"manufacturer": "NRCHKB",
"model": "1.3.6",
"serialNo": "Default Serial Number",
"firmwareRev": "1.3.6",
"hardwareRev": "1.3.6",
"softwareRev": "1.3.6",
"cameraConfigVideoProcessor": "ffmpeg",
"cameraConfigSource": "",
"cameraConfigStillImageSource": "",
"cameraConfigMaxStreams": 2,
"cameraConfigMaxWidth": 1280,
"cameraConfigMaxHeight": 720,
"cameraConfigMaxFPS": 10,
"cameraConfigMaxBitrate": 300,
"cameraConfigVideoCodec": "libx264",
"cameraConfigAudioCodec": "libfdk_aac",
"cameraConfigAudio": false,
"cameraConfigPacketSize": 1316,
"cameraConfigVerticalFlip": false,
"cameraConfigHorizontalFlip": false,
"cameraConfigMapVideo": "0:0",
"cameraConfigMapAudio": "0:1",
"cameraConfigVideoFilter": "scale=1280:720",
"cameraConfigAdditionalCommandLine": "-tune zerolatency",
"cameraConfigDebug": false,
"cameraConfigSnapshotOutput": "disabled",
"cameraConfigInterfaceName": "",
"characteristicProperties": "{}",
"waitForSetupMsg": false,
"outputs": 2,
"x": 150,
"y": 180,
"87882341.f7e72"
"id": "87882341.f7e72",
"type": "switch",
"name": "Motion Bypass Off",
"property": "BedroomMotionBypass",
"propertyType": "global",
"rules": [
"t": "eq",
"v": "true",
"vt": "jsonata"
"t": "eq",
"v": "false",
"vt": "jsonata"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 390,
"y": 180,
"56d28fa8.491c1"
"id": "d8aa7de5.7c546",
"type": "trigger",
"op1": "",
"op2": "",
"op1type": "nul",
"op2type": "payl",
"duration": "480",
"extend": true,
"overrideDelay": false,
"units": "s",
"reset": "true",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 170,
"y": 280,
"8305b788.e96978"
"id": "8305b788.e96978",
"type": "switch",
"name": "Timer Cancel On",
"property": "BedroomTimerCancel",
"rules": [
"t": "eq",
"v": "true",
"vt": "jsonata"
"t": "eq",
"v": "false",
"vt": "jsonata"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 450,
"y": 280,
"a51d9fc7.3a16a"
"id": "f049c77f.3cd768",
"type": "link in",
"name": "Occupancy Switch",
"links": [
"40dcd44.884712c",
"8d959318.8eda3",
"a81f0428.559c38",
"ed7c313f.c8553"
"x": 195,
"y": 60,
"88fcfb8345a7c430"
"id": "64472eb1.62606",
"type": "within-time-switch",
"name": "Daytime/Nighttime Lights On",
"nameInt": "",
"positionConfig": "9b3a306f.b1c6e",
"startTime": "06:00",
"startTimeType": "entered",
"startOffset": 0,
"startOffsetType": "none",
"startOffsetMultiplier": 60000,
"endTime": "02:00",
"endTimeType": "entered",
"endOffset": 0,
"endOffsetType": "none",
"endOffsetMultiplier": 60000,
"timeRestrictions": 0,
"timeRestrictionsType": "none",
"timeDays": "*",
"timeOnlyOddDays": false,
"timeOnlyEvenDays": false,
"timeMonths": "*",
"timedatestart": "",
"timedateend": "",
"propertyStart": "",
"propertyStartType": "none",
"propertyStartCompare": "true",
"propertyStartThreshold": "",
"propertyStartThresholdType": "num",
"startTimeAlt": "",
"startTimeAltType": "entered",
"startOffsetAlt": 0,
"startOffsetAltType": "none",
"startOffsetAltMultiplier": 60000,
"propertyEnd": "",
"propertyEndType": "none",
"propertyEndCompare": "true",
"propertyEndThreshold": "",
"propertyEndThresholdType": "num",
"endTimeAlt": "",
"endTimeAltType": "entered",
"endOffsetAlt": 0,
"endOffsetAltType": "none",
"endOffsetAltMultiplier": 60000,
"tsCompare": "0",
"x": 200,
"y": 360,
"373a4cac.be08d4"
"8d571151.84274"
"id": "373a4cac.be08d4",
"type": "switch",
"name": "Sleeping?",
"property": "SleepingStatus",
"rules": [
"t": "eq",
"v": "false",
"vt": "jsonata"
"t": "eq",
"v": "true",
"vt": "jsonata"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 480,
"y": 340,
"546c5c57.6247b4"
"bce524a2.b39bd8"
"id": "8d571151.84274",
"type": "switch",
"rules": [
"t": "eq",
"v": "true",
"vt": "jsonata"
"t": "eq",
"v": "false",
"vt": "jsonata"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 480,
"y": 380,
"bce524a2.b39bd8"
"475c9560.63d6ec"
"id": "67f3051b.0b73ec",
"type": "zigbee2mqtt-out",
"name": "Bedroom Nightstands",
"server": "a9e92c14.0a08e",
"friendly_name": "Bedroom Nightstands",
"device_id": "4",
"command": "payload",
"commandType": "msg",
"payload": "payload",
"payloadType": "msg",
"transition": 0,
"x": 920,
"y": 360,
"id": "a51d9fc7.3a16a",
"name": "Bedroom Off",
"device_id": "4",
"payload": "{\"state\":\"OFF\",\"transition\":2}",
"payloadType": "json",
"transition": 0,
"x": 710,
"y": 280,
"id": "546c5c57.6247b4",
"type": "function",
"name": "Bright",
"func": "msg = {\n payload: {\n \"state\": \"ON\",\n \"brightness\": 254,\n \"color_temp\": global.get('colorTemp'),\n \"transition\": 2\n }\n};\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 690,
"y": 320,
"67f3051b.0b73ec"
"id": "bce524a2.b39bd8",
"type": "function",
"name": "Low",
"func": "msg = {\n payload: {\n \"state\": \"ON\",\n \"brightness\": 82,\n \"color_temp\": global.get('colorTemp'),\n \"transition\": 2\n }\n};\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 690,
"y": 360,
"67f3051b.0b73ec"
"id": "475c9560.63d6ec",
"type": "function",
"name": "Dimmed",
"func": "msg = {\n payload: {\n \"state\": \"ON\",\n \"brightness\": 167,\n \"color_temp\": global.get('colorTemp'),\n \"transition\": 2\n }\n};\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 700,
"y": 400,
"67f3051b.0b73ec"
"id": "3fe982f51697fe6f",
"type": "link in",
"name": "Trigger",
"links": [
"8db2499b8a59f007"
"x": 855,
"y": 180,
"d8aa7de5.7c546"
"id": "88fcfb8345a7c430",
"type": "trigger",
"op1": "",
"op2": "{ \"On\":false }",
"op1type": "pay",
"op2type": "json",
"duration": "15",
"extend": false,
"units": "s",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 170,
"y": 120,
"7ac14fb9.11fb7"
"id": "480b5cc0.4ea614",
"type": "homekit-bridge",
"bridgeName": "node-red",
"pinCode": "979-91-688",
"port": "",
"advertiser": "ciao",
"allowInsecureRequest": false,
"model": "1.3.6",
"customMdnsConfig": false,
"mdnsMulticast": true,
"mdnsInterface": "",
"mdnsPort": "",
"mdnsIp": "",
"mdnsTtl": "",
"mdnsLoopback": true,
"mdnsReuseAddr": true,
"allowMessagePassthrough": true
"id": "9b3a306f.b1c6e",
"type": "position-config",
"isValide": "true",
"longitude": "0",
"latitude": "0",
"angleType": "deg",
"timeZoneOffset": 99,
"timeZoneDST": 0,
"stateTimeFormat": "3",
"stateDateFormat": "12"
"id": "a9e92c14.0a08e",
"type": "zigbee2mqtt-server",
"name": "zigbee2mqtt",
"host": "localhost",
"mqtt_port": "1883",
"mqtt_username": "",
"mqtt_password": "",
"tls": "",
"usetls": false,
"base_topic": "zigbee2mqtt"
