Ok, back to my other question - structures and how they are shown
WRT this thread:
I got confused trying to make a payload and did it the wrong way.
Mia culpa.
So I was thinking about HOW I was thinking wrongly.
Here's why I was making that mistake.
Example flow:
inject - function - debug
[{"id":"8b10d682f4fe2612","type":"inject","z":"26262ba1.62dcbc","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":5000,"y":7180,"wires":[["f4f62a0bc9525937"]]},{"id":"f4f62a0bc9525937","type":"function","z":"26262ba1.62dcbc","name":"Start tirigger","func":"const device = \"Foo\"\n\nmsg.topic = device + \"/cmnd/power1\"\n\nnode.warn(\"Device \" + device)\n\nmsg.payload = {\n    config: {\n        name: device\n    }\n}\n\nreturn msg","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":5155,"y":7180,"wires":[["2d5eeb80655c6a5a"]],"l":false},{"id":"2d5eeb80655c6a5a","type":"debug","z":"26262ba1.62dcbc","name":"debug 77","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":5330,"y":7180,"wires":[]}]
I was wanting to make a message with the structure:
msg.payload.config.name
(hint - there's part of the problem)
I was ACTUALLY wanting it to be:
msg.payload = {
    config: {
So the elephant in the room - for me at least - when I look in the debug ad copy the path I am told/given
payload.config.name
Yes, I know: I have been here for a few years now. I should know better.
But as I take a lot of things literally........ (What I see)
I think it would be more intuitive if it was shown as:
payload{config{name}}
Hi @Trying_to_learn
The standard JavaScript syntax for a path to a variable inside an object is payload.config.name. That is what you are given because that is what you'd using in a function node, for example, to access that variable.
We aren't going to invent a non-standard syntax for this.
Ok. I was only explaining the path I went down and the mistakes that tripped me up.
If that is the way, then I can't expect it to change.
But I hope others have read this and it has saved then from making te same mistake themselves.
Just to be a bit pedantic for clarity. This is the text you would paste into a change node or similar. That is why it doesn't have msg. on the front (which you need for use in function nodes of course).
My understanding is that it is this way because less experienced users are more likely to need to paste the property path into another node than they are to use a function node.
