OMRON FINS Trigger signal using bit
Hello guys, I've been using the OMRON FINS node to trigger a signal.
Issue is, how do I trigger a signal just like a differentiate up function?
  • Move the bit/bool result into msg.payload
  • Use an RBE node to block unless change
  • Use a switch node to only allow true (or 1) to pass
OMRON --> CHANGE (copy value to payload) --> RBE (only output when value changes) --> SWITCH (is it on?)
Thanks so much Steve!
