Omron FINS Write & Buffer-Parser String
Hi all,
I am trying to send 1 string variable to an omron "CP1L" PLC
My goal in this test is to send 8 characters: "abcdefghij" to the 5 memory channels D2110...D2114
2 characters on each channel
However, I only manage to send one character to each channel.
In this way the string does not look good. 10 channels instead of 5.
I am doing something wrong. I hope you can help me.
Thanks in advance
Json Code:
        "id": "8cee613acd48c93d",
        "type": "tab",
        "label": "string to PLC",
        "disabled": false,
        "info": "",
        "env": []
        "id": "655187c5c69cb47d",
        "type": "buffer-parser",
        "z": "8cee613acd48c93d",
        "data": "payload",
        "dataType": "msg",
        "specification": "spec",
        "specificationType": "ui",
        "items": [
                "type": "byte",
                "name": "item1",
                "offset": 0,
                "length": 10,
                "offsetbit": 0,
                "scale": "1",
                "mask": ""
        "swap1": "",
        "swap2": "",
        "swap3": "",
        "swap1Type": "swap",
        "swap2Type": "swap",
        "swap3Type": "swap",
        "msgProperty": "payload",
        "msgPropertyType": "str",
        "resultType": "value",
        "resultTypeType": "output",
        "multipleResult": true,
        "fanOutMultipleResult": false,
        "setTopic": true,
        "outputs": 1,
        "x": 1190,
        "y": 340,
                "d6e72b2886026920",
                "137fcbce36ef6b68"
        "id": "d6e72b2886026920",
        "type": "debug",
        "name": "to byte Array",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "payload",
        "statusType": "auto",
        "x": 1250,
        "y": 400,
        "id": "9a9cacb1ecfa0e66",
        "type": "inject",
        "name": "abcdefghij",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": "7",
        "topic": "",
        "payload": "abcdefghij",
        "payloadType": "str",
        "x": 760,
        "y": 340,
                "c17a9f731cc5d8f4",
                "265ce15741e2dcfa"
        "id": "a92407da7bbb3f32",
        "type": "debug",
        "name": "as a buffer",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "x": 1010,
        "y": 400,
        "id": "c17a9f731cc5d8f4",
        "type": "debug",
        "name": "string data",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "x": 790,
        "y": 400,
        "id": "7725cd9626bd2c49",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1630,
        "y": 340,
        "id": "137fcbce36ef6b68",
        "type": "FINS Write",
        "connection": "7e9569d1d6c8014c",
        "addressType": "str",
        "address": "D2110",
        "dataType": "msg",
        "data": "payload",
        "x": 1430,
        "y": 340,
                "7725cd9626bd2c49"
        "id": "265ce15741e2dcfa",
        "type": "function",
        "name": "string to buffer",
        "func": "var buf = Buffer(msg.payload); \nmsg.payload = buf;\nreturn msg;\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 960,
        "y": 340,
                "655187c5c69cb47d",
                "a92407da7bbb3f32"
        "id": "7e9569d1d6c8014c",
        "type": "FINS Connection",
        "name": "CP1L Test",
        "host": "192.168.3.10",
        "port": "9600",
        "MODE": "",
        "MODEType": "CP",
        "protocol": "",
        "protocolType": "tcp",
        "ICF": "128",
        "DNA": "1",
        "DA1": "10",
        "DA2": "0",
        "SNA": "",
        "SA1": "99",
        "SA2": "",
        "autoConnect": true
There is a a built in demo
Press CTRL+I on your keybaord...
Thank you very much!, it works!
