Hi guys, I need to read and write data from an Omron-plc (CP1L) to a raspberry pi 4 with :
1- rs 232 to USB cable or
2- USB-b To USB or
3- rs232 to ethernet cable using node-red. Can you please help me?
Do you have an Ethernet module fitted to the PLC?
If not, then you could (probably) use the CP1W-CIF41 Omron adaptor to give the PLC ethernet THEN you can use this node: node-red-contrib-omron-fins (node) - Node-RED
Hi, thank you for your reply. I ordered an Ethernet to RS232 module. But I don't know how to set up the fins nodes. Can you please explain to me?
Which module?
FINS is an Ethernet protocol - meaning it needs to connect to the PLC Ethernet stack (without serial in the mix)
So with which node I can read data from my PLC with this R3232 to ethernet module?
I have been working on a C-MODE (host protocol) addition that might do the job (but it is not released - only in a development branch) other than that, you can build CMODE (host protocol) commands in node-red and send them (via serial or to a serial server) and process the response. The OMRON manuals have extensive details on hostlink protocol.
Thank you . With this device that I have I can add a VCOM port and I can set a host IP address . Still doesn't work with fins nodes ?
Do you already have the Ethernet-serial device?
Ok, so could you open a putty or hyperterminal, connect the the VCOM and transmit @00RD0000001057* followed by a CR (carriage return AKA ASCII 13 - you can do this with alt - 1 - 3 on number keypad if enter key doesnt work)
Do you get a response?
If not,
- are you using an official OMRON Serial Cable?
- have you set the Serial Server settings to match PLC settings? ( I see you have set speed 57600 8-n-1 - does this match the COM port settings of the PLC)
- do you see the COM LED flicker on the PLC?
If none of that works, please state exactly what your setup is (including cable numbers, pin outs, PLC settings etc)
Hi, so I have tested and released (beta) of the package that supports C-Mode commands (hostlink serial protocol)
You would need to install the package via command line to test it node-red-contrib-omron-fins@1.0.0-beta-1 (you do this in your node-red user directory - usually c:\users\user-name\.node-red or ~/.node-red)
Demo...
[{"id":"1e3d488899442e63","type":"C-Mode Command","z":"7ecba32db86f0617","name":"Read D300[5]","plcSeries":"CSJP","hostNumber":0,"headerCode":"RD","p1":"300","p2":"5","p3":"","x":520,"y":900,"wires":[["6f28a1bf4f0f1279"]]},{"id":"eab4f15d02965743","type":"C-Mode Response","z":"7ecba32db86f0617","name":"","x":950,"y":900,"wires":[["593fd0917c0eed02"]]},{"id":"1d9c4152b061277a","type":"inject","z":"7ecba32db86f0617","name":"trigger","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":150,"y":900,"wires":[["1e3d488899442e63"]]},{"id":"b724ed24d7ab4420","type":"serial request","z":"7ecba32db86f0617","name":"","serial":"5abddf654cd7c41c","x":790,"y":900,"wires":[["eab4f15d02965743"]]},{"id":"593fd0917c0eed02","type":"debug","z":"7ecba32db86f0617","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"","statusType":"counter","x":1130,"y":900,"wires":[]},{"id":"d55e47925d055523","type":"C-Mode Command","z":"7ecba32db86f0617","name":"Write DM area","plcSeries":"CSJP","hostNumber":0,"headerCode":"WD","p1":"","p2":"","p3":"","x":520,"y":960,"wires":[["6f28a1bf4f0f1279"]]},{"id":"854639688e75a6c6","type":"catch","z":"7ecba32db86f0617","name":"","scope":["eab4f15d02965743"],"uncaught":false,"x":990,"y":960,"wires":[["0ed83a6223dfcadb"]]},{"id":"2a077efedc791411","type":"inject","z":"7ecba32db86f0617","name":"D300 [0,0,0]","props":[{"p":"p1","v":"300","vt":"str"},{"p":"p2","v":"[0,0,0]","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":170,"y":960,"wires":[["d55e47925d055523"]]},{"id":"6f28a1bf4f0f1279","type":"delay","z":"7ecba32db86f0617","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"10","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":705,"y":900,"wires":[["b724ed24d7ab4420"]],"l":false},{"id":"fedec3b8b770d49b","type":"inject","z":"7ecba32db86f0617","name":"D300 [-1,-2,-3] (bad data)","props":[{"p":"p1","v":"300","vt":"str"},{"p":"p2","v":"[-1,-2,-3]","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":210,"y":1000,"wires":[["d55e47925d055523"]]},{"id":"df99ad47a8bd3b23","type":"inject","z":"7ecba32db86f0617","name":"D300 [65535,9999,10000]","props":[{"p":"p1","v":"300","vt":"str"},{"p":"p2","v":"[65535,9999,10000]","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":210,"y":1040,"wires":[["d55e47925d055523"]]},{"id":"eb49cf62e07c6ea8","type":"C-Mode Command","z":"7ecba32db86f0617","name":"Read dynamic","plcSeries":"CSJP","hostNumber":0,"headerCode":"","p1":"","p2":"","p3":"","x":500,"y":1180,"wires":[["6f28a1bf4f0f1279"]]},{"id":"d7363e6cb06c1aed","type":"inject","z":"7ecba32db86f0617","name":"RR 100 5","props":[{"p":"topic","vt":"str"},{"p":"headerCode","v":"RR","vt":"str"},{"p":"p1","v":"100","vt":"num"},{"p":"p2","v":"5","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Read CIO","x":160,"y":1160,"wires":[["eb49cf62e07c6ea8"]]},{"id":"3c352e98e3202941","type":"C-Mode Command","z":"7ecba32db86f0617","name":"Write dynamic","plcSeries":"CSJP","hostNumber":0,"headerCode":"","p1":"","p2":"","p3":"","x":500,"y":1300,"wires":[["6f28a1bf4f0f1279"]]},{"id":"d609f2b4d7a9c285","type":"inject","z":"7ecba32db86f0617","name":"WR 100 [0,1,2]","props":[{"p":"topic","vt":"str"},{"p":"headerCode","v":"WR","vt":"str"},{"p":"p1","v":"100","vt":"num"},{"p":"p2","v":"[0,1,2]","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Write CIO100","x":180,"y":1260,"wires":[["3c352e98e3202941"]]},{"id":"65365e1f385bae05","type":"inject","z":"7ecba32db86f0617","name":"WR 100 [65535,9999,10000]","props":[{"p":"topic","vt":"str"},{"p":"headerCode","v":"WR","vt":"str"},{"p":"p1","v":"100","vt":"num"},{"p":"p2","v":"[65535,9999,10000]","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Write CIO100","x":220,"y":1300,"wires":[["3c352e98e3202941"]]},{"id":"f613c7f34f9c8230","type":"inject","z":"7ecba32db86f0617","name":"RH 50 10","props":[{"p":"topic","vt":"str"},{"p":"headerCode","v":"RH","vt":"str"},{"p":"p1","v":"50","vt":"num"},{"p":"p2","v":"10","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Read HR","x":160,"y":1200,"wires":[["eb49cf62e07c6ea8"]]},{"id":"f9fce412bb2aa69f","type":"inject","z":"7ecba32db86f0617","name":"WH 52 [0,1,2]","props":[{"p":"topic","vt":"str"},{"p":"headerCode","v":"WH","vt":"str"},{"p":"p1","v":"52","vt":"num"},{"p":"p2","v":"[0,1,2]","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Write HR52","x":170,"y":1360,"wires":[["3c352e98e3202941"]]},{"id":"74112485758bd950","type":"inject","z":"7ecba32db86f0617","name":"WH 50 [65535,8,7,6,5,4,3,2,1,0]","props":[{"p":"topic","vt":"str"},{"p":"headerCode","v":"WH","vt":"str"},{"p":"p1","v":"50","vt":"num"},{"p":"p2","v":"[65535,8,7,6,5,4,3,2,1,0]","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Write HR50","x":230,"y":1400,"wires":[["3c352e98e3202941"]]},{"id":"c072f49b7fbb104f","type":"comment","z":"7ecba32db86f0617","name":"** SETUP COM PORT **","info":"","x":810,"y":860,"wires":[]},{"id":"8d310d8f7ec001aa","type":"comment","z":"7ecba32db86f0617","name":"Read and Write to the area determined dynamically by input parameters","info":"","x":330,"y":1120,"wires":[]},{"id":"4ddc6196f128a907","type":"comment","z":"7ecba32db86f0617","name":"Read and Write DM area (address and count determined by input parameters)","info":"","x":350,"y":860,"wires":[]},{"id":"4e5d4243059aaae0","type":"inject","z":"7ecba32db86f0617","name":"trigger","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":150,"y":700,"wires":[["8ccea540558de6e3"]]},{"id":"8ccea540558de6e3","type":"C-Mode Command","z":"7ecba32db86f0617","name":"Read D310[2]","plcSeries":"CSJP","hostNumber":0,"headerCode":"RD","p1":"310","p2":"2","p3":"","x":520,"y":700,"wires":[["6f28a1bf4f0f1279"]]},{"id":"28f61fe4f41c56d3","type":"C-Mode Command","z":"7ecba32db86f0617","name":"Write D310 1, D311 2","plcSeries":"CSJP","hostNumber":0,"headerCode":"WD","p1":"310","p2":"[ 1 , 2 ]","p3":"","x":500,"y":740,"wires":[["6f28a1bf4f0f1279"]]},{"id":"f29dee8fb458d67c","type":"inject","z":"7ecba32db86f0617","name":"trigger","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":150,"y":740,"wires":[["28f61fe4f41c56d3"]]},{"id":"3e3aaaf497c9267b","type":"C-Mode Command","z":"7ecba32db86f0617","name":"Write D310 65535, D311 0","plcSeries":"CSJP","hostNumber":0,"headerCode":"WD","p1":"310","p2":"[65535, 0]","p3":"","x":480,"y":780,"wires":[["6f28a1bf4f0f1279"]]},{"id":"60a6e5ec4388b19e","type":"inject","z":"7ecba32db86f0617","name":"trigger","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":150,"y":780,"wires":[["3e3aaaf497c9267b"]]},{"id":"4985fe9cfe3a3e9a","type":"comment","z":"7ecba32db86f0617","name":"Read and Write fixed DM areas (D310 & D311)","info":"","x":260,"y":660,"wires":[]},{"id":"0ed83a6223dfcadb","type":"debug","z":"7ecba32db86f0617","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"","statusType":"counter","x":1130,"y":960,"wires":[]},{"id":"5abddf654cd7c41c","type":"serial-port","serialport":"COM5","serialbaud":"9600","databits":"7","parity":"even","stopbits":"2","waitfor":"@","dtr":"none","rts":"none","cts":"none","dsr":"none","newline":"*","bin":"bin","out":"char","addchar":"","responsetimeout":"1000"}]
