On/off/blink functionality
flows-4.json (5.1 KB)
Hi. I use node-red on my boat to control a physical LED panel which shows the status of the electrical equipment on board. I use Shelly relays.
When my water heater is turned on I would like my LED light to indicate this by being on all the time. When the water heater is active (heating water) I would like the LED to blink. When the water heater is turned off I would like the LED to be off.
I tried to make this, but have run into trouble. I have attached the flow in the post. Currently the system always will make the LED blink or be turned off because this node overrides the other nodes (see flow).
Mathias
I am not familiar with your blink node, but shouldn't your "idle or active" switch be downstream of the "on/off" switch?
(I may have LED on and LED off the wrong way round!)
Ah, perfect. This was the help I needed. Much appreciated.
