I am new Node-red, I have a requirement where in I need to do some processing in each custom node, when the node is deployed successfully. I don't see any callback on Deploy. at the node level. Could you please guide me on this.
whenever a new set of flows are deploy all of the existing node objects are discarded and new node objects created. So your node constructor will be called to create those new instances.
If the user does a modified-nodes/flows type of deploy, then any unmodified nodes will not be touched and will not know the deploy is happening.
Thanks for the reply. The solution works for me.
