Issue in deploying flow after modifying
I have created simple custom nodes to send messages in Node RED. I'm facing issue when I modify the flow and deploy it. Changes wont get reflected first time. If I delete the changes and make same changes again, then it works. For example if I have a flow with nodes x, y , z with x -> y -> z and if I add a->y , this change doesn't get reflected first time. But if I delete node a and again add it second time, then it works. I'm not sure why this is happening.
I'm using Node-RED v3.0.2 and node.js v16.20.1. I'm building Node RED from source.
Any help on fixing this issue will be greatly appreciated.
If you try it on a normal install of node red do you see the same problem?
What do you mean by 'does not get reflected`? What exact symptom are you seeing?
Also what are these nodes a,x,y,z? Are they all custom nodes that you have created?
Thank you for the reply.
I will try this normal install and check.
When I make new connection a->y to the existing working flow x->y->z and deploy this new flow, the messages from node a are not sent to node y and the logs I have added in node a are not printed. But the flow x->y->z works fine. If I delete node a and reconnect it again to y second time, then message from node a is sent to node y and logs in node a are printed.
yes, a, x, y, z are the custom nodes I have created which has simple functionality to send a message.
Is this related to your previous post in which you are trying to send a message when a new connection is made rather than under more normal circumstances? If so then I suggest continuing this on the original thread as it appears that the technique used to achieve that is not functioning as expected.
No, this is a different issue. This is not related to my previous post. I'm trying to send message under normal circumstances here.
In that case try it with the standard node-red and let us know the result.
sure, I will check and let you know.
I am facing the same issue with standard node-red too.
You will have to provide more detail as your current description is hard to understand.
Remember, we cannot see what you see and you havent linked us to a code repo or shown any code.
Can you provide a gif or series of pictures (with annotations) that clearly describe your issue?
I will share the github repo link for the code I have used soon
Under what circumstance does your node send messages? Is it when it receives a message? If it is then add logging into that code to see where it is failing.
@Steve-Mcl , @Colin Steps to reproduce the issue
I have added my test code in this github repository
Steps to reproduce the issue.
  1. Move to .node-red directory
    cd ~/.node-red
  2. Install custom-node
    npm install node-red-test/custom-node/
  3. Install send-node
    npm install node-red-test/send-node/
  4. Run node-red
    node-red
  5. Create the below flow
  6. Deploy the flow to see the below output of debug node
    {key : "dummy"}
  7. Update the flow as below by making new connections
  8. Deploy the updated flow to see below output
    Expected output -
    {key : "dummy"}
    {key : "dummy"}
    Produced output :
    {key : "dummy"}
  9. Delete the extra nodes you added Step 7 and deploy the flow. Add the extra nodes back again as in Step 7 and deploy. Now it produces output as expected.
Please let me know if you are able to reproduce the issue or if you have need any clarifications.
Note : The issue doesn't occur always but it occurs frequently
You have not responded to my previous post.
I have created two nodes namely, send-node and custom-node. send-node sends message when it is deployed. custom-node forwards message when it receives input message
probably a race condition because you are attempting to send before the node is fully created (i.e. before the current block is finished) and, more importantly, before Node-RED has emitted its update events.
As a test, put the node.send call in a setImmediate, nextTick or setTimeout
e.g.
    msg._info = 'inside node creation, before it is fully registered'
    node.send(msg);
    setTimeout(() => {
        msg._info = 'setTimeout'
        node.send(msg);
    }, 1); // 1 ms
    setImmediate(() => {
        msg._info = 'setImmediate'
        node.send(msg);
    process.nextTick(() => {
        msg._info = 'nextTick'
        node.send(msg);
and check the msg using a debug (set to show full msg object)
I will try this to see if it works @Steve-Mcl . Thank you
Sending message after node is fully created solves the issue. Thank you @Steve-Mcl for the solution. Thank you @Colin
