One flow is working the other one isnt
I have these two flows that shall reinstate some input numbers in Home Assistant, I got the one with "High" to work, while the "Low"gives me error
        "id": "489e97254938079a",
        "type": "server-state-changed",
        "z": "7b83b20cb732bf2a",
        "name": "Setverdi høy pris",
        "server": "12135e641a9670e0",
        "version": 4,
        "exposeToHomeAssistant": false,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "input_number.multiplier_high",
        "entityidfiltertype": "exact",
        "outputinitially": false,
        "state_type": "str",
        "haltifstate": "",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "outputs": 1,
        "output_only_on_state_change": true,
        "for": "0",
        "forType": "num",
        "forUnits": "minutes",
        "ignorePrevStateNull": false,
        "ignorePrevStateUnknown": false,
        "ignorePrevStateUnavailable": false,
        "ignoreCurrentStateUnknown": false,
        "ignoreCurrentStateUnavailable": false,
        "outputProperties": [
                "property": "payload",
                "propertyType": "msg",
                "value": "",
                "valueType": "entityState"
                "property": "data",
                "value": "",
                "valueType": "eventData"
                "property": "topic",
                "value": "",
                "valueType": "triggerId"
        "x": 140,
        "y": 3260,
                "57f57d080cdb6a63"
        "id": "57f57d080cdb6a63",
        "type": "change",
        "name": "set memory",
        "rules": [
                "t": "set",
                "p": "multiplier_high",
                "pt": "flow",
                "to": "payload",
                "tot": "msg",
                "dc": true
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 330,
        "y": 3260,
        "id": "c3376fda3e61f658",
        "type": "change",
        "name": "Get memory",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "multiplier_high",
                "tot": "flow",
                "dc": true
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 550,
        "y": 3260,
                "a658471e3def1aa4"
        "id": "cd3c86ce10cc8f46",
        "type": "link in",
        "name": "link in 22",
        "links": [
            "692081b344ef1ccd"
        "x": 425,
        "y": 3220,
                "c3376fda3e61f658"
        "id": "19d7895a6011b722",
        "type": "debug",
        "name": "debug 304",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 1170,
        "y": 3260,
        "id": "8205f47920efd81d",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 380,
        "y": 3320,
                "c3376fda3e61f658"
        "id": "a658471e3def1aa4",
        "type": "function",
        "name": "function 1",
        "func": "msg.payload = Number(msg.payload);\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 740,
        "y": 3260,
                "3e32f318d96c8db5"
        "id": "3e32f318d96c8db5",
        "type": "api-call-service",
        "name": "Multiplier high",
        "version": 5,
        "debugenabled": false,
        "domain": "input_number",
        "service": "set_value",
        "areaId": [],
        "deviceId": [],
        "entityId": [],
        "data": "{\"entity_id\":\"input_number.multiplier_high\",\"value\":\"{{flow.multiplier_high}}\"}",
        "dataType": "json",
        "mergeContext": "",
        "mustacheAltTags": false,
        "outputProperties": [],
        "queue": "none",
        "mergecontext": "",
        "x": 920,
        "y": 3260,
                "19d7895a6011b722"
        "id": "ef9e25776057db0d",
        "name": "Setverdi lav pris",
        "version": 4,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "input_number.multiplier_low",
        "haltifstate": "",
        "outputs": 1,
        "for": "0",
        "forType": "num",
                "value": "",
                "property": "data",
                "value": "",
                "value": "",
        "x": 140,
        "y": 3080,
                "4570999eb497a792"
        "id": "4570999eb497a792",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "#:(file)::multiplier_low",
                "pt": "flow",
                "to": "payload",
                "tot": "msg",
                "dc": true
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 330,
        "y": 3080,
        "id": "6248af32760b93d5",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "#:(file)::multiplier_low",
                "tot": "flow",
                "dc": true
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 550,
        "y": 3080,
                "900b0948afdc9787"
        "id": "78ad09ecb5d80d3f",
        "type": "link in",
        "name": "link in 21",
        "links": [
            "692081b344ef1ccd"
        "x": 425,
        "y": 3040,
                "6248af32760b93d5"
        "id": "1e9a10334331fa17",
        "type": "debug",
        "name": "debug 303",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1170,
        "y": 3140,
        "id": "efec0a24b22f1c76",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 380,
        "y": 3140,
                "6248af32760b93d5"
        "id": "900b0948afdc9787",
        "type": "function",
        "name": "function 2",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 740,
        "y": 3080,
                "a283ae636071d563",
                "da226fcd5ad51f13"
        "id": "a283ae636071d563",
        "name": "Multiplier Low",
        "version": 5,
        "debugenabled": true,
        "areaId": [],
        "deviceId": [],
        "entityId": [],
        "data": "{\"entity_id\":\"input_number.multiplier_low\",\"value\":\"{{flow.multiplier_low}}\"}",
        "dataType": "json",
        "mergeContext": "",
        "queue": "none",
        "mergecontext": "",
        "x": 920,
        "y": 3080,
                "1e9a10334331fa17"
        "id": "da226fcd5ad51f13",
        "type": "debug",
        "name": "debug 305",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 870,
        "y": 3180,
        "id": "12135e641a9670e0",
        "type": "server",
        "name": "Home Assistant",
        "version": 5,
        "addon": false,
        "rejectUnauthorizedCerts": true,
        "ha_boolean": "y|yes|true|on|home|open",
        "connectionDelay": true,
        "cacheJson": true,
        "heartbeat": false,
        "heartbeatInterval": "30",
        "areaSelector": "friendlyName",
        "deviceSelector": "friendlyName",
        "entitySelector": "friendlyName",
        "statusSeparator": "at: ",
        "statusYear": "hidden",
        "statusMonth": "short",
        "statusDay": "numeric",
        "statusHourCycle": "h23",
        "statusTimeFormat": "h:m",
        "enableGlobalContextStore": true
Anyone see why?
Add another debug node showing what is coming out of the function 1. Set all debug nodes to output Complete Message. Make sure you expand all the objects in the debug pane, then the messages can be compared.
Like this?
Skjermbilde 2023-07-10 kl. 22.57.52
Add debug nodes to the Get Memory nodes to see what values you are writing the flow variables to. Also check in the Context window that they are correct
I find it strange if I in the Json paste in the text from the high, then it works but if I just change high with low, then h... is loose.
I think this may be better answered by someone on a Home Assistant forum.
Yes I think so, there must be a reason even if I cant see it at this point. Thanks for your effort though.
Not much activity on Home Assistant forum or in their discord channel. Solved the problem anyway. When working with codes and flow I often think to much, and do not keep things simple enough. anyway, this is how it ended up.
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "x": 1170,
        "y": 3060,
        "id": "d5e1e7d856f50aa8",
        "type": "change",
        "rules": [
                "t": "set",
                "pt": "flow",
                "to": "payload",
                "tot": "msg",
                "dc": true
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 370,
        "y": 3040,
        "id": "e89cf3e1c29f0c8d",
        "type": "link in",
        "links": [
            "692081b344ef1ccd"
        "x": 425,
        "y": 2980,
                "4318117196b92849"
        "id": "7f70f393539079f7",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 380,
        "y": 3100,
                "4318117196b92849"
        "id": "1a968f1197530b9d",
        "name": "Multiplier low",
        "version": 5,
        "areaId": [],
        "deviceId": [],
        "entityId": [],
        "data": "{\"entity_id\":\"input_number.multiplier_low\",\"value\":\"{{payload}}\"}",
        "dataType": "json",
        "mergeContext": "",
        "queue": "none",
        "mergecontext": "",
        "x": 910,
        "y": 3060,
                "1e9a10334331fa17"
        "id": "4318117196b92849",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "flow",
                "dc": true
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 570,
        "y": 3060,
                "1a968f1197530b9d"
        "id": "cf771aec22acaa95",
        "version": 4,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "state_type": "num",
        "haltifstate": "",
        "outputs": 1,
        "for": "0",
        "forType": "num",
                "value": "",
                "property": "data",
                "value": "",
                "value": "",
        "x": 140,
        "y": 3040,
                "d5e1e7d856f50aa8"
        "type": "server",
        "version": 5,
        "addon": false,
        "cacheJson": true,
        "heartbeat": false,
