One node-red to another (different rpi's)
I have one RPi with a hardware buttons wired up to it that I would like to speak to another RPi with an output (controlling a HW relay) - both running node-red obviously.
How do I send a message from the one rpi to the other? They are on the same network.
M
I think using MQTT would be your best bet/solution as it's quick and easy to set-up.
I will have a play with that - thanks.
Btw, the Rpi's are not on a internet accessible network. (dont know if that makes a difference to the solution).
That shouldn't matter - in fact it's safer.
Have a look at installing Mosquitto (MQTT broker) on both RPi, then you could use the MQTT In and Out nodes to transfer data between the Pi(es).
I think you should find a number of articles on the forum about what you are trying to do.
Thanks again. So I need a broker on both pi's I take it?
No, you do not need a broker on both Pis.
You can pick one of your Pis to run the broker, and connect to it from all of the Pis (including itself).
Awesome. It works.
Just for reference, you could have used raw TCP, websocket or http nodes as well. All would work but undoubtedly, MQTT gives you a much more resilient solution without having to do the donkey work yourself.
