Hi, I have a problem with opc ua connection and certificate.
This is Console log problem.
I only try to connect with one item node and one opc client node.
Hi. Firstly, do not post screenshots for text.
- They are not searchable (for future readers with similar problems)
- They are harder to read than text
- I cannot copy + paste bits back to ask questions - having to screenshot screenshots is tedious.
So part of the issue might be permissions (storing things on desktop under a user account is never a good thing).
Secondly, do you see all the back slashes?
Try specifying file paths with a regular slash / e.g. c:/a_folder_every_user_can_access/my_cert.xyz
Sorry for mistakes.
I've changed all the back slashes and changed the directory but same situation.
08:25:07.874Z :client_secure_channel_layer :545 xxxxx <<<<<< _on_message_received ERROR requestId= 1 Object response.responseHeader.requestHandle= 0 ServiceFault
08:25:07.875Z :client_base_impl :531 Inner create secure channel has failed serviceResult = BadInternalError (0x80020000)
Client connect error: The connection may have been rejected by server,
Err = ( serviceResult = BadInternalError (0x80020000))
4 Sep 10:25:08 - [warn] [OpcUa-Client:651ed428d71aa592] OpcUaClientNode: Case A: Endpoint does not contain, 1==None 2==Sign 3==Sign&Encrypt, using securityMode: [3]
4 Sep 10:25:08 - [warn] [OpcUa-Client:651ed428d71aa592] OpcUaClientNode: using securityPolicy: ["http://opcfoundation.org/UA/SecurityPolicy#Basic256Sha256"]
4 Sep 10:25:08 - [warn] [OpcUa-Client:651ed428d71aa592] OpcUaClientNode: Case B: UserName & password does not match to server (needed by Sign or SignAndEncrypt), check username: undefined and password: undefined
4 Sep 10:25:08 - [warn] [OpcUa-Client:651ed428d71aa592] OpcUaClientNode: Case C: With Sign you cannot use SecurityPolicy None!!
4 Sep 10:25:08 - [warn] [OpcUa-Client:651ed428d71aa592] OpcUaClientNode: Invalid endpoint parameters:
4 Sep 10:25:08 - [error] [OpcUa-Client:651ed428d71aa592] Client node error on: error: ["Wrong endpoint parameters: {\"id\":\"01cb127cd282b3df\",\"type\":\"OpcUa-Endpoint\",\"_closeCallbacks\":[],\"_inputCallback\":null,\"_inputCallbacks\":null,\"wires\":[],\"_wireCount\":0,\"credentials\":{},\"endpoint\":\"opc.tcp://192.168.1.200:4840/\",\"securityPolicy\":\"Basic256Sha256\",\"securityMode\":\"SignAndEncrypt\",\"login\":false,\"none\":false,\"usercert\":true,\"userCertificate\":\"C:\\\\Users\\\\Administrator\\\\Desktop\\\\opcua\\\\user\\\\opcua-user-cert-20230901-105422.der\",\"userPrivatekey\":\"C:\\\\Users\\\\Administrator\\\\Desktop\\\\opcua\\\\user\\\\opcua-user-cert-20230901-105422.key.pem\",\"user\":null,\"password\":null}"]
4 Sep 10:25:08 - [error] [OpcUa-Client:651ed428d71aa592] Invalid endpoint
08:25:08.300Z :client_base_impl :531 Inner create secure channel has failed ClientTCP_transport18: socket has been disconnected by third party
4 Sep 10:25:08 - [error] [OpcUa-Browser:3c737e93cc319db0] Browse node error!
08:25:09.761Z :client_base_impl :531 Inner create secure channel has failed ClientTCP_transport19: socket has been disconnected by third party
Err = (ClientTCP_transport19: socket has been disconnected by third party)
4 Sep 10:25:09 - [warn] [OpcUa-Client:8f68edae182ffeaf] OpcUaClientNode: Case A: Endpoint does not contain, 1==None 2==Sign 3==Sign&Encrypt, using securityMode: [3]
4 Sep 10:25:09 - [warn] [OpcUa-Client:8f68edae182ffeaf] OpcUaClientNode: using securityPolicy: ["http://opcfoundation.org/UA/SecurityPolicy#Basic256Sha256"]
4 Sep 10:25:09 - [warn] [OpcUa-Client:8f68edae182ffeaf] OpcUaClientNode: Case B: UserName & password does not match to server (needed by Sign or SignAndEncrypt), check username: undefined and password: undefined
4 Sep 10:25:09 - [warn] [OpcUa-Client:8f68edae182ffeaf] OpcUaClientNode: Case C: With Sign you cannot use SecurityPolicy None!!
4 Sep 10:25:09 - [warn] [OpcUa-Client:8f68edae182ffeaf] OpcUaClientNode: Invalid endpoint parameters:
4 Sep 10:25:09 - [error] [OpcUa-Client:8f68edae182ffeaf] Client node error on: error: ["Wrong endpoint parameters: {\"id\":\"548f5c3b94ed54b4\",\"type\":\"OpcUa-Endpoint\",\"_closeCallbacks\":[],\"_inputCallback\":null,\"_inputCallbacks\":null,\"wires\":[],\"_wireCount\":0,\"credentials\":{},\"endpoint\":\"opc.tcp://192.168.1.200:4840/HEIDENHAIN/NC\",\"securityPolicy\":\"Basic256Sha256\",\"securityMode\":\"SignAndEncrypt\",\"login\":false,\"none\":false,\"usercert\":true,\"userCertificate\":\"C:/Users/Administrator/AppData/Roaming/node-red-opcua-nodejs/Config/UserPKI/own/certs/opcua-user-cert-20230901-105422.der\",\"userPrivatekey\":\"C:/Users/Administrator/AppData/Roaming/node-red-opcua-nodejs/Config/UserPKI/own/private/opcua-user-cert-20230901-105422.key.pem\",\"user\":null,\"password\":null}"]
4 Sep 10:25:09 - [error] [OpcUa-Client:8f68edae182ffeaf] Invalid endpoint
4 Sep 10:25:10 - [error] [OpcUa-Server:itc640] Disconnect error:
You must provide username & password as Sign means you want to use them.
