i am trying to acquire data with this opc-ua client: node-red-contrib-iiot-opcua (I know it is no longer maintained) and I would like to be able to read data that can only be seen via "Event View" (this is how it is called by the opc-ua UaExper client software under "Document" > "Add..." > "Document Type" > "Event View":
Do you know how to do this kind of opc-ua reading?
If someone succeeded could you kindly send me an example or explain me how to make this kind of flow?
I am also open to the possibility of using the node node-red-contrib-opcua is there any example?
Thanks in advance.
