OPC UA & Node Red stalling loading Nodes
I have an issue with Node Red not loading back up after a reboot when using the OPC UA Contrib node. It stalls loading the Nodes. If i remove the node via NPM in CLI it just kills it all together.
Any help would be much appreciated.
Symon
@bceyresy If you want help with an issue I suggest you provide details so people can help you.
  1. What device and os are you running NR on?
  2. What version of NR and node-js are you using (see the startup log)
  3. What is the full name of the node at issue (i.e. node-red-contrib-?????)
  4. Provide a copy of the startup log
  5. are you using Docker and/or Home Assistant
Make it easy for people to help you otherwise they may just pass over your issue after all we are all just volunteers.
Thank you for the replay @zenofmud .
  1. The device was using s Brainboxes BB-400 Industrial Edge controller.
    https://www.brainboxes.com/product/industrial-edge-controller/bb-400
  2. Node Red version was 3.x then we updated to latest 4x version and still the same.
  3. Th node used was the - node-red-contrib-opcua
  4. I will need to recreate the fault again as we flashed the device and used another OPC US node. I did take one screen shot attached here.
Screenshot 2024-08-06 160715
We are not using docker or home assistant. However i did spin up a docker and had some bizare similar issue where once i put the nodes onto the flow, I deployed with them disconnected then lost connection to the interface & had to reboot docker container.
It could be hardware related or Node Red related. If the image attached could help point in a direction that would be helpful, i will recreate the fault and post back later on.
Symon
