Is there anybody who can gives me an example for the open-red-otgw.
http:// node-red/opentherm/node-red-contrib-otgw
I tried several efforts eg
serial
input
wifi
Dick
Hi @dick
There was an example on the Node's Read Me.
I don't use it myself, but maybe it will help
1stsetup/node-red-contrib-otgw: A node for node-red to connect to the OpenTherm Gateway (github.com)
[{"id":"6ddf1fe5.fe5f1","type":"tab","label":"OpenTherm Gateway","disabled":false,"info":""},{"id":"f3d55c2b.34fd38","type":"debug","z":"6ddf1fe5.fe5f1","name":"cmd/data/events","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":832,"y":159,"wires":[]},{"id":"b042e675.4d869","type":"debug","z":"6ddf1fe5.fe5f1","name":"Gateway to Boiler","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":840,"y":200,"wires":[]},{"id":"17229d10.ac9cbb","type":"debug","z":"6ddf1fe5.fe5f1","name":"From Boiler","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":820,"y":240,"wires":[]},{"id":"18905ec7.5ae3a9","type":"debug","z":"6ddf1fe5.fe5f1","name":"From Thermostat","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":840,"y":280,"wires":[]},{"id":"6882a4f5.0dfa04","type":"debug","z":"6ddf1fe5.fe5f1","name":"Gateway to Thermostat","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":860,"y":320,"wires":[]},{"id":"fb84cace.f8719","type":"inject","z":"6ddf1fe5.fe5f1","name":"PR=A (Get About opentherm gateway)","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"cmd","payload":"PR=A","payloadType":"str","x":250,"y":180,"wires":[["eb3eec5.bf1469"]]},{"id":"eb3eec5.bf1469","type":"otgw","z":"6ddf1fe5.fe5f1","name":"","serialdevice":"/dev/ttyUSB0","baudrate":9600,"dataBits":8,"stopBits":1,"parity":"none","rtscts":false,"xon":false,"xoff":false,"xany":false,"debug":true,"x":560,"y":260,"wires":[["f3d55c2b.34fd38"],["b042e675.4d869"],["17229d10.ac9cbb"],["18905ec7.5ae3a9"],["6882a4f5.0dfa04"]]},{"id":"addec53f.3a5fa","type":"inject","z":"6ddf1fe5.fe5f1","name":"data","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"data","x":350,"y":120,"wires":[["eb3eec5.bf1469"]]},{"id":"508597ac.a5ac5","type":"inject","z":"6ddf1fe5.fe5f1","name":"SH=72.5 (Set Heating Setpoint)","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"cmd","payload":"SH=72.5","payloadType":"str","x":270,"y":220,"wires":[["eb3eec5.bf1469"]]},{"id":"b49d723b.99df38","type":"inject","z":"6ddf1fe5.fe5f1","name":"PS=1 (Enable Print Summary mode)","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"cmd","payload":"PS=1","payloadType":"str","x":260,"y":360,"wires":[["eb3eec5.bf1469"]]},{"id":"cd86f477.9e932","type":"inject","z":"6ddf1fe5.fe5f1","name":"PS=0 (Disable Print Summary mode)","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"cmd","payload":"PS=0","payloadType":"str","x":260,"y":400,"wires":[["eb3eec5.bf1469"]]},{"id":"c2115ecb.a067","type":"inject","z":"6ddf1fe5.fe5f1","name":"GW=1 (Gateway mode)","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"cmd","payload":"GW=1","payloadType":"str","x":300,"y":280,"wires":[["eb3eec5.bf1469"]]},{"id":"b0a05fc8.a32cb8","type":"inject","z":"6ddf1fe5.fe5f1","name":"GW=0 (Monitor mode)","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"cmd","payload":"GW=0","payloadType":"str","x":300,"y":320,"wires":[["eb3eec5.bf1469"]]}]
I have moved this into General as the category Creating Nodes is for developing Node RED Nodes, not using using.
thanks for the help
I know that page and the flow but there is a sentence what i do not understand:
Specify a name an the serial device to which the OTGW is connected.
Specify a name ??
the flow example gives:
otgwData/node Gateway?
that is the problem.
Dick
I suggest raising an issue with the developer.
Having a look at the source code on GitHub
its not even using your configured serial device.
its forcibly setting it to /dev/ttyUSB0, and I can not see any changes to that.
That might be ok for one environment, but is certainly not for all, i.e: another USB serial device gets initialised first.
Furthermore The name property is not used for any serial setup, neither is it used in any command
It was last modified 2 years.
