Outputting Text to a Windows file
I see from a previous post "Outputting text to a Windows shared folder" that Node Red running on Home Assistant on a Raspberry Pi cant output text to a Windows Folder as HA blocks that and only a modification to HA will allow that.
Is this still the case or is there another way to use something like the Write File node to send text data to a Windows folder. I tried various way specifying the file path incl UNC and no luck.
Sounds like a good question for the HA forum. I think they run in a container so unless they grant that permission to write “ anywhere “ then you may be stuck.
Thank you I have asked the question on the HA forum.
Thanlk you I have asked the question on the HA forum.
