hi everyone I should be able to overwrite the properties of the email node.
at this moment I can only write the property To.
there is a way to be able to overwrite these properties.
because I have to change them from the dashboard.
Thanks in advance.
The built in help tells you what properties of msg to set.
If I remember right, msg.topic becomes the subject, msg.payload becomes the body.
Note. User ID and password are not settable at runtime.
OK thank you very much
