Owl Intuition & Node Red
I’m a newbee here so go easy please… :roll_eyes:
Just getting into node_red and must say I getting more and more hooked!! Basically I’m creating a home automation system, which I’ve connected up my Ikea Tradfri lighting system which all fully works, and I’m now looking at doing similar with my Solar panel / energy / heating system, which is controlled via owl intuition.
Anybody come across this and know of any (is it), node.js / palletes, I can import, as I did for my Tradfri system.
Thanks in advance.
You can search the list of easily downloadable nodes for node-RED at flows.nodered.org
But there isn’t one for the owl intuition
There is however a nodejs package https://www.npmjs.com/package/owlintuition
which depending on your coding skills you could either use in a function node or create a node-RED node for yourself and others to use
Okay cheers,
Downloaded that js but must admit looks like its gona take me some time to get my head around it.
I’ll do plenty of googling / you-tubing and keep ya informed of progress… or lack off haha!
Cheers
Ive just got this working with node red and owl using multicast - enjoy!
[{"id":"a457620e.f65ab","type":"udp in","z":"92a1db89.afc3c","name":"Owl Solar PV","iface":"","port":"22600","ipv":"udp6","multicast":"true","group":"224.192.32.19","datatype":"utf8","x":90,"y":160,"wires":[["f7bdc329.33e96","911d8b6b.142ec"]]},{"id":"f7bdc329.33e96","type":"debug","z":"92a1db89.afc3c","name":"Owl Solar PV","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":290,"y":120,"wires":[]},{"id":"2b6535a8.70624a","type":"comment","z":"92a1db89.afc3c","name":"SOLAR DATA PACKET","info":"SOLAR DATA PACKET\nEXAMPLE PACKET\n<solar id='00A0C914C851'>\n<current><generating units='w'>0.00</generating><exporting units='w'>0.00</exporting></current> <day><generated units='wh'>0.00</generated><exported units='wh'>0.00</exported></day>\n</solar>\nPARAMETERS\nThe main <solar> tag contains sections for the current solar readings (<current>) and the totals for the day (<day>). Both sections have <generated> and <exported> tags that contain the values for power generated by the PV system and power exported to the electricity grid.\n       \nTag Attribute Description\n \n \n Solar Id The MAC Address of the Network OWL\n \n \nCurr/Day units Units for the value in the xml tag.\nwh = Watt Hours, divide by 1000 to get kWh\nw = watts","x":120,"y":60,"wires":[]},{"id":"61020896.a85b9","type":"function","z":"92a1db89.afc3c","name":"setup global variable solarPvId","func":"global.set(\"solarPvId\",msg.payload);","outputs":1,"noerr":0,"x":970,"y":160,"wires":[[]]},{"id":"e89ee7a7.c2547","type":"function","z":"92a1db89.afc3c","name":"setup global variable currentGeneratingUnitsW","func":"global.set(\"currentGeneratingUnitsW\",msg.payload);","outputs":1,"noerr":0,"x":1020,"y":320,"wires":[[]]},{"id":"3a8f2163.0372ee","type":"function","z":"92a1db89.afc3c","name":"setup global variable exportingUnitsW","func":"global.set(\"exportingUnintsW\",msg.payload);","outputs":1,"noerr":0,"x":990,"y":400,"wires":[[]]},{"id":"a76b4c59.edded8","type":"function","z":"92a1db89.afc3c","name":"setup global variable currentDayGeneratedW","func":"global.set(\"currentDayGeneratedW\",msg.payload);","outputs":1,"noerr":0,"x":1010,"y":480,"wires":[[]]},{"id":"8d1ca736.41c668","type":"function","z":"92a1db89.afc3c","name":"setup global variable currentDayExportedW","func":"global.set(\"currentDayExportedW\",msg.payload);","outputs":1,"noerr":0,"x":1010,"y":560,"wires":[[]]},{"id":"95e77e78.d73ee8","type":"ui_gauge","z":"92a1db89.afc3c","name":"Currently generating","group":"1c8bae75.1a8cc2","order":1,"width":0,"height":0,"gtype":"gage","title":"Currently generating","label":"watts","format":"{{value}}","min":0,"max":"4000","colors":["#fff86b","#e4ef65","#77bb40"],"seg1":"500","seg2":"1000","x":1380,"y":320,"wires":[]},{"id":"47888bc7.49628c","type":"string","z":"92a1db89.afc3c","name":"Currently exporting","methods":[{"name":"between","params":[{"type":"str","value":"<exporting units='w'>"},{"type":"str","value":"</exporting>"}]},{"name":"toFloat","params":[{"type":"num","value":"1"}]}],"prop":"payload","propout":"payload","object":"msg","objectout":"msg","x":650,"y":400,"wires":[["1dfe9485.77303b","3a8f2163.0372ee","2dbd9789.07b2e8"]]},{"id":"f44fa393.091f88","type":"string","z":"92a1db89.afc3c","name":"Current Generated Today","methods":[{"name":"between","params":[{"type":"str","value":"</current><day><generated units='wh'>"},{"type":"str","value":"</generated>"}]},{"name":"toFloat","params":[{"type":"num","value":"1"}]}],"prop":"payload","propout":"payload","object":"msg","objectout":"msg","x":670,"y":480,"wires":[["eeaa251.4743158","a76b4c59.edded8","a4033c78.2e002"]]},{"id":"70690e94.be7ae8","type":"string","z":"92a1db89.afc3c","name":"Current Exported Today","methods":[{"name":"between","params":[{"type":"str","value":"</generated><exported units='wh'>"},{"type":"str","value":"</exported></day>"}]},{"name":"toFloat","params":[{"type":"num","value":"1"}]}],"prop":"payload","propout":"payload","object":"msg","objectout":"msg","x":670,"y":560,"wires":[["dbd8a396.0e275","8d1ca736.41c668","571bd31d.ee846c"]]},{"id":"1dfe9485.77303b","type":"ui_gauge","z":"92a1db89.afc3c","name":"Currently Exporting","group":"1c8bae75.1a8cc2","order":2,"width":0,"height":0,"gtype":"gage","title":"Currently Exporting","label":"watts","format":"{{value}}","min":0,"max":"4000","colors":["#e0eed4","#77bb40","#253d0e"],"seg1":"","seg2":"","x":1370,"y":400,"wires":[]},{"id":"eeaa251.4743158","type":"ui_chart","z":"92a1db89.afc3c","name":"Current Generated today","group":"1c8bae75.1a8cc2","order":3,"width":0,"height":0,"label":"Current Generated Today","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"20000","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":1390,"y":480,"wires":[[]]},{"id":"dbd8a396.0e275","type":"ui_chart","z":"92a1db89.afc3c","name":"Curent Exported Today","group":"1c8bae75.1a8cc2","order":4,"width":0,"height":0,"label":"Curent Exported Today","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"20000","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":1380,"y":560,"wires":[[]]},{"id":"e9df09e8.66e178","type":"function","z":"92a1db89.afc3c","name":"setup global variable solarPvTimestamp","func":"global.set(\"solarPvTimestamp\",msg.payload);","outputs":1,"noerr":0,"x":1000,"y":240,"wires":[[]]},{"id":"6f1fcfc5.d41cb8","type":"debug","z":"92a1db89.afc3c","name":"currently generating","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":930,"y":280,"wires":[]},{"id":"2dbd9789.07b2e8","type":"debug","z":"92a1db89.afc3c","name":"currently exporting","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":930,"y":360,"wires":[]},{"id":"2ef9e1a.a61b91e","type":"debug","z":"92a1db89.afc3c","name":"solarPvId","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":900,"y":120,"wires":[]},{"id":"c9963bf6.5f93b8","type":"debug","z":"92a1db89.afc3c","name":"solarPvTimesatmp","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":930,"y":200,"wires":[]},{"id":"571bd31d.ee846c","type":"debug","z":"92a1db89.afc3c","name":"exported today","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":920,"y":520,"wires":[]},{"id":"a4033c78.2e002","type":"debug","z":"92a1db89.afc3c","name":"generated today","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":920,"y":440,"wires":[]},{"id":"b2261e35.756fd","type":"function","z":"92a1db89.afc3c","name":"Combine 6 global  variables into one payload","func":"msg.payload = \n\n{\n\"solarPvId\"                :   global.get(\"solarPvId\"),\n\"solarPvTimestamp\"         :   global.get(\"solarPvTimestamp\"),\n\"currentGeneratingUnitsW\"  :   global.get(\"currentGeneratingUnitsW\"),\n\"exportingUnintsW\"         :   global.get(\"exportingUnintsW\"),\n\"currentDayGeneratedW\"     :   global.get(\"currentDayGeneratedW\"),\n\"currentDayExportedW\"      :   global.get(\"currentDayExportedW\")\n\n}\nreturn msg;\n\n","outputs":1,"noerr":0,"x":1010,"y":680,"wires":[["c0767150.926098","af8667d0.b85ea8"]]},{"id":"260df5be.3d8a7a","type":"inject","z":"92a1db89.afc3c","name":"","topic":"","payload":"","payloadType":"date","repeat":"10","crontab":"","once":true,"onceDelay":0.1,"x":550,"y":680,"wires":[["b2261e35.756fd"]]},{"id":"911d8b6b.142ec","type":"switch","z":"92a1db89.afc3c","name":"Take only from SOLAR bundle","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"<solar id=","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":350,"y":160,"wires":[["457fd844.5a8eb8","c220840c.46ed38","70119ac4.d203b4","47888bc7.49628c","f44fa393.091f88","70690e94.be7ae8"]]},{"id":"c0767150.926098","type":"debug","z":"92a1db89.afc3c","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1350,"y":640,"wires":[]},{"id":"457fd844.5a8eb8","type":"string","z":"92a1db89.afc3c","name":"solarPvId","methods":[{"name":"between","params":[{"type":"str","value":"<solar id='"},{"type":"str","value":"'>"}]}],"prop":"payload","propout":"payload","object":"msg","objectout":"msg","x":620,"y":160,"wires":[["61020896.a85b9","2ef9e1a.a61b91e"]]},{"id":"c220840c.46ed38","type":"string","z":"92a1db89.afc3c","name":"timestamp","methods":[{"name":"between","params":[{"type":"str","value":"<timestamp>"},{"type":"str","value":"</timestamp>"}]}],"prop":"payload","propout":"payload","object":"msg","objectout":"msg","x":630,"y":240,"wires":[["e9df09e8.66e178","c9963bf6.5f93b8"]]},{"id":"70119ac4.d203b4","type":"string","z":"92a1db89.afc3c","name":"Currently Generating Units","methods":[{"name":"between","params":[{"type":"str","value":"<current><generating units='w'>"},{"type":"str","value":"</generating>"}]},{"name":"toFloat","params":[{"type":"num","value":"1"}]}],"prop":"payload","propout":"payload","object":"msg","objectout":"msg","x":680,"y":320,"wires":[["6f1fcfc5.d41cb8","e89ee7a7.c2547","95e77e78.d73ee8"]]},{"id":"af8667d0.b85ea8","type":"influxdb out","z":"92a1db89.afc3c","influxdb":"242678f7.d4b1","name":"OwlSolarPV","measurement":"stations","precision":"","retentionPolicy":"","x":1350,"y":680,"wires":[]},{"id":"a8d2b461.5fe31","type":"comment","z":"92a1db89.afc3c","name":"This Flow takes Owl multicast output and divides it to be an influx database","info":"","x":300,"y":620,"wires":[]},{"id":"26f5863e.514102","type":"comment","z":"92a1db89.afc3c","name":"Owl appears to pump out electricty parameteres as well as solar so the witch only goes to the solar package","info":"","x":850,"y":60,"wires":[]},{"id":"1c8bae75.1a8cc2","type":"ui_group","z":"","name":"SolarPV","tab":"2f11a8c0.5a5aa","disp":true,"width":"6","collapse":false},{"id":"242678f7.d4b1","type":"influxdb","z":"","hostname":"192.168.199.109","port":"8086","protocol":"http","database":"OwlSolarPV","name":"OwlSolarPV","usetls":false,"tls":""},{"id":"2f11a8c0.5a5aa","type":"ui_tab","z":"","name":"MK14 7PH","icon":"dashboard","disabled":false,"hidden":false}]
Good work!
Can you also add it to the flows library on flows.nodered.org?
Now have done so :slight_smile:
