Pagination Tabulator in ui-table
hi I need use pagination in ui-table
and use this to UI-control node but not happen anything
    "Tabulator": {
        "layout": "fitColumns",
        "responsiveLayout": "hide",
        "tooltips": true,
        "addRowPos": "top",
        "history": true,
        "pagination": "local",
        "paginationSize": 7,
        "movableColumns": true,
        "resizableRows": true,
        "initialSort": [
                "column": "name",
                "dir": "asc"
        "columns": [
                "title": "Name",
                "field": "name",
                "editor": "input"
                "title": "Task Progress",
                "field": "progress",
                "hozAlign": "left",
                "formatter": "progress",
                "editor": true
                "title": "Gender",
                "field": "gender",
                "width": 95,
                "editor": "select",
                "editorParams": {
                    "values": [
                        "male",
                        "female"
                "title": "Rating",
                "field": "rating",
                "formatter": "star",
                "hozAlign": "center",
                "width": 100,
                "editor": true
                "title": "Color",
                "field": "col",
                "width": 130,
                "editor": "input"
                "title": "Date Of Birth",
                "field": "dob",
                "width": 130,
                "sorter": "date",
                "title": "Driver",
                "field": "car",
                "width": 90,
                "formatter": "tickCross",
                "sorter": "boolean",
                "editor": true
so ui-table support tabulator pagination if yes how use it
Pagination works with ajax requests. You have to find a way to establish a http node or server responding to these requests.
Ui-table can’t help you with this as it completely do all data exchange via javascript on client side and a webservice link to Node-RED.
There is „local pagination“ available. Have to do some tests to find out how this works.
But tabulator is very efficient with big tables. I managed to hold a couple of 1,000 rows in my syslog server flow with usable scrolling and filtering.
normally my data fetched by button navigation and send command to mongodb to generate data
but problem cant see button navigation (next, prev page ... ) in UI-table only data
so how use tabulator in node-red
Ui-table only interfaces to tabulator and do no processing. ui-control.tabulator is basically passed without any modification (except declaring the callback functions) and all commands are passed through.
Perhaps (local) pagination is a newer feature. UI-table uses a older but stable version (but I can’t tell you out of my head which)
Perhaps first try to look at the browser console for any error or info messages
