Parse JSON object
Hi guys, I'm not sure if this is the right place to ask this question but I have a JSON document like this:
{"Info":{"Battery":0,"ID":1,"Latitudine":"45.47","Longitudine":"9.19"},"Data":[[{"AcX":16688,"AcY":104,"AcZ":2064,"time":1618343910},{"AcX":16680,"AcY":128,"AcZ":2052,"time":1618346910},{"AcX":16676,"AcY":180,"AcZ":1816,"time":1618349910},{"AcX":16616,"AcY":188,"AcZ":1968,"time":1618352910},{"AcX":16592,"AcY":196,"AcZ":1844,"time":1618355910},{"AcX":16712,"AcY":116,"AcZ":2036,"time":1618358910},{"AcX":16596,"AcY":104,"AcZ":2044,"time":1618361910},{"AcX":16672,"AcY":52,"AcZ":1860,"time":1618364910},{"AcX":16736,"AcY":172,"AcZ":2000,"time":1618367910}]]}
that is sent to node-red through HTTP, once received the packet I need to store every value in my Inlfuxdb. Eventually the DB should have 9 columns:
Info | Battery | ID | Latitudine | Longitudine | AcX | AcY | AcZ | time
My problem is: How can I read every single value if I got a nested Object and a nested Array? Is there any function to split my object (I already tried to use the split node but I end up with the first four values and then the array with AcX, AcY, AcZ and time).
Thanks a lot in advance!
  1. Use a change node to ...
    1. set msg.info to msg.payload.Info
    2. set msg.payload to msg.payload.Data[0]
  2. then link the change node to a split node.
    1. each message should now have the data element in msg.payload and the Info property in msg.info
  3. then link the split node to a function node
    1. in there, you can combine the items in msg.payload and msg.info into 1 object using a function node with...
var influxData = {
   ...msg.info,
   ...msg.payload
msg.payload = influxData;
Is that a JSON string or have you already converted it to a javascript object? If it is a string then you need to first to feed it through a JSON node to convert it to an object.
You should use the influx batch node for this. That can write the whole set in one go, though you will need to restructure it a bit, the easiest way to do that is in a function node. Make sure you convert any field values to numbers before passing to influx, if they are not numbers already. Do the Battery, ID, Lattitude, and Longitude values refer to all the following data? If so then you need to decide whether thay are fields or tags.
Well this is my flow and my output without changing anything, Latitude and Longitude are characters and not numbers
Did you try my suggestion?
It works!
Demo flow...
[{"id":"7a15c50b.023a4c","type":"inject","z":"a86654ec.266648","name":"your data","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"Info\":{\"Battery\":0,\"ID\":1,\"Latitudine\":\"45.47\",\"Longitudine\":\"9.19\"},\"Data\":[[{\"AcX\":16688,\"AcY\":104,\"AcZ\":2064,\"time\":1618343910},{\"AcX\":16680,\"AcY\":128,\"AcZ\":2052,\"time\":1618346910},{\"AcX\":16676,\"AcY\":180,\"AcZ\":1816,\"time\":1618349910},{\"AcX\":16616,\"AcY\":188,\"AcZ\":1968,\"time\":1618352910},{\"AcX\":16592,\"AcY\":196,\"AcZ\":1844,\"time\":1618355910},{\"AcX\":16712,\"AcY\":116,\"AcZ\":2036,\"time\":1618358910},{\"AcX\":16596,\"AcY\":104,\"AcZ\":2044,\"time\":1618361910},{\"AcX\":16672,\"AcY\":52,\"AcZ\":1860,\"time\":1618364910},{\"AcX\":16736,\"AcY\":172,\"AcZ\":2000,\"time\":1618367910}]]}","payloadType":"json","x":138,"y":704,"wires":[["dc59b3eb.14ac3"]]},{"id":"dc59b3eb.14ac3","type":"change","z":"a86654ec.266648","name":"set msg.info and msg.payload","rules":[{"t":"set","p":"info","pt":"msg","to":"payload.Info","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"payload.Data[0]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":352,"y":704,"wires":[["93d921f4.e0493"]]},{"id":"93d921f4.e0493","type":"split","z":"a86654ec.266648","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":130,"y":768,"wires":[["eff51f68.4d8ff"]]},{"id":"eff51f68.4d8ff","type":"function","z":"a86654ec.266648","name":"merge .info and .payload","func":"var influxData = {\n   ...msg.info,\n   ...msg.payload\n}\ninfluxData.Latitudine = Number(influxData.Latitudine);\ninfluxData.Longitudine = Number(influxData.Longitudine);\nmsg.payload = influxData;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":316,"y":768,"wires":[["b6f82563.22a778"]]},{"id":"b6f82563.22a778","type":"debug","z":"a86654ec.266648","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":518,"y":768,"wires":[]}]
I was trying it but I got some errors, I'm checking what I did wrong
Ok it works, probably I didn't set properly the function node! Thanks a lot!
Now after the function node is it possible to store all the objects in one array or object? I need to store them in a temporary file for others get request but I need all the nine object and I cant append them to the file because when I retrieve another set of nine objects I need to overwrite the temporary file
attach a join node
result...
Thanks a lot! Sorry for the noob question but I'm really new here
I thought you were writing them to influx.
Just for info
This is one of the few times using a change node and JSONata is just as fast and cleaner, as there is no need to rejoin split array.
[{"id":"7a15c50b.023a4c","type":"inject","z":"5a245aa1.510164","name":"your data","props":[{"p":"payload"},{"p":"topic","v":"","vt":"date"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"Info\":{\"Battery\":0,\"ID\":1,\"Latitudine\":\"45.47\",\"Longitudine\":\"9.19\"},\"Data\":[[{\"AcX\":16688,\"AcY\":104,\"AcZ\":2064,\"time\":1618343910},{\"AcX\":16680,\"AcY\":128,\"AcZ\":2052,\"time\":1618346910},{\"AcX\":16676,\"AcY\":180,\"AcZ\":1816,\"time\":1618349910},{\"AcX\":16616,\"AcY\":188,\"AcZ\":1968,\"time\":1618352910},{\"AcX\":16592,\"AcY\":196,\"AcZ\":1844,\"time\":1618355910},{\"AcX\":16712,\"AcY\":116,\"AcZ\":2036,\"time\":1618358910},{\"AcX\":16596,\"AcY\":104,\"AcZ\":2044,\"time\":1618361910},{\"AcX\":16672,\"AcY\":52,\"AcZ\":1860,\"time\":1618364910},{\"AcX\":16736,\"AcY\":172,\"AcZ\":2000,\"time\":1618367910}]]}","payloadType":"json","x":230,"y":4540,"wires":[["dc59b3eb.14ac3"]]},{"id":"dc59b3eb.14ac3","type":"change","z":"5a245aa1.510164","name":"set msg.info and msg.payload","rules":[{"t":"set","p":"info","pt":"msg","to":"payload.Info","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"payload.Data[0]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":444,"y":4540,"wires":[["93d921f4.e0493"]]},{"id":"93d921f4.e0493","type":"split","z":"5a245aa1.510164","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":222,"y":4604,"wires":[["eff51f68.4d8ff"]]},{"id":"eff51f68.4d8ff","type":"function","z":"5a245aa1.510164","name":"merge .info and .payload","func":"var influxData = {\n   ...msg.info,\n   ...msg.payload\n}\ninfluxData.Latitudine = Number(influxData.Latitudine);\ninfluxData.Longitudine = Number(influxData.Longitudine);\nmsg.payload = influxData;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":408,"y":4604,"wires":[["b6f82563.22a778","6af1a26b.2258e4"]]},{"id":"b6f82563.22a778","type":"debug","z":"5a245aa1.510164","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":670,"y":4580,"wires":[]},{"id":"6af1a26b.2258e4","type":"join","z":"5a245aa1.510164","name":"","mode":"auto","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":"false","timeout":"","count":"","reduceRight":false,"x":520,"y":4640,"wires":[["666008bf.e4439"]]},{"id":"666008bf.e4439","type":"debug","z":"5a245aa1.510164","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"$millis() - topic","statusType":"jsonata","x":720,"y":4640,"wires":[]},{"id":"6e195fb5.65b33","type":"inject","z":"5a245aa1.510164","name":"","props":[{"p":"payload"},{"p":"topic","v":"","vt":"date"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"Info\":{\"Battery\":0,\"ID\":1,\"Latitudine\":\"45.47\",\"Longitudine\":\"9.19\"},\"Data\":[[{\"AcX\":16688,\"AcY\":104,\"AcZ\":2064,\"time\":1618343910},{\"AcX\":16680,\"AcY\":128,\"AcZ\":2052,\"time\":1618346910},{\"AcX\":16676,\"AcY\":180,\"AcZ\":1816,\"time\":1618349910},{\"AcX\":16616,\"AcY\":188,\"AcZ\":1968,\"time\":1618352910},{\"AcX\":16592,\"AcY\":196,\"AcZ\":1844,\"time\":1618355910},{\"AcX\":16712,\"AcY\":116,\"AcZ\":2036,\"time\":1618358910},{\"AcX\":16596,\"AcY\":104,\"AcZ\":2044,\"time\":1618361910},{\"AcX\":16672,\"AcY\":52,\"AcZ\":1860,\"time\":1618364910},{\"AcX\":16736,\"AcY\":172,\"AcZ\":2000,\"time\":1618367910}]]}","payloadType":"json","x":140,"y":4440,"wires":[["517b19ca.010be8"]]},{"id":"517b19ca.010be8","type":"change","z":"5a245aa1.510164","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"($info := $each(payload.Info, function($v, $k){{$k:$number($v)}});\tpayload.Data[0].$merge([$,$info])\t)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":4440,"wires":[["f13da7e6.5a62","823320ad.ae198"]]},{"id":"f13da7e6.5a62","type":"split","z":"5a245aa1.510164","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":510,"y":4440,"wires":[["809051e9.7d5008"]]},{"id":"823320ad.ae198","type":"debug","z":"5a245aa1.510164","name":"array","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":640,"y":4400,"wires":[]},{"id":"809051e9.7d5008","type":"debug","z":"5a245aa1.510164","name":"split array","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"$millis() - topic","statusType":"jsonata","x":710,"y":4440,"wires":[]}]
   $info := $each(
       payload.Info,
Yes, I'm doing both because I need to store every values in infuxdb but also I need to create a temporary file
If you need the data later you could read it back from Influx, or if it is in node-red that you need it then save it in context memory.
@E1cid I really wish I could get my head around JSONata that is pretty cool
